Strobes on Kubota BX
   / Strobes on Kubota BX #11
I also bought a set of 4 strobes with control box on Ebay for my BX for $10. They shipped from China with no problem.
1. not really a 'control box'... but rather the strobes have a lead that when connected to hot, will change the flash sequence.
2. Yes. I connected each control lead (see #1) from the strobe together, then to a momentary switch. It is a push button. Each time i press it, all strobes advance to the next flash pattern. I think they have something like 10 different flash patterns.
   / Strobes on Kubota BX #13
In regard to my particular strobe system:
1.) It is a control box.
2.) It has a on and off switch and 3 switches to alter the flash patterns.
3.) For 10 bucks.... well worth the money.
   / Strobes on Kubota BX #16
I installed strobe lights on my bx25 kubota, we wanted to install strobes light on are tractor because i use it to clear are sidewalks in my neighborhood because the city will not do it. I had the idea to putt the strobes lights on the safety bars cage but it’s too hard to make a hole thru it. So i found an other idea, i used 2 15 inch metal tool box to mount the lights on. I used 4 1-2/1 inch bolts to hold it on around the safety bar with an other metal plate. I used an 12 inch box to put the control panel on with the plugs for the lights.
And as a 16 year old this is really impressive.
   / Strobes on Kubota BX #17
Wow, they should be able to see you coming now! Good job!
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2021 John Deere XUV865M (A57149)
2021 John Deere...
ATLAS COPCO V4 LIGHT TOWER / GENERATOR (A52709)
ATLAS COPCO V4...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
