Stripped transmission drain plug - Ford 4100
   / Stripped transmission drain plug - Ford 4100 #1
Other Bob
Basehor, KS
1981 Ford 4100
I bought an 80's Ford 4100 diesel a couple of years ago and I need to change the transmission fluid. However the plug is stripped, so I can't get it out. It's the type with an inverted 1/2 inch square which was almost completely rounded. I couldn't get any bite with my 1/2 breaker bar so I ordered some extractors. The plug seems to be soft metal as the extractors seem to get a little bit of a bite and then just start eating away material.
I'm not sure what else to try, I was going to try and collapse in the sides so that the threads would be loose but it sits almost flush with the transmission housing so I can't really get much forse from the outside.
Any suggestions?
   / Stripped transmission drain plug - Ford 4100 #2
   / Stripped transmission drain plug - Ford 4100 #3
Thanks for that link... I think. I had to go back a good number of pages to even find anything related to actually getting the plug out. I had no idea drain plugs could cause so much conversation. Sounds like his was more of a standard plug with a hex head. Mine is more like the picture:
That being said I think I'll have to end up doing something similar and drill it out. I don't have a bit nearly as big as the plug, I'm guessing it's close to an inch in diameter. I was thinking about using a small bit and drilling holes in a v - pattern to make a pie shaped section that I can knock out and then try collapsing the rest. My fear is damaging threads or cracking the housing.
   / Stripped transmission drain plug - Ford 4100 #7
All that he said was "Drain plug" and everybody started having flashbacks. Good luck, I hope that it doesn't take a year and 2000 posts to get it out. ;)
   / Stripped transmission drain plug - Ford 4100 #8
Oh... we are much smarter now after that learning experience and as such, better able to help! :D
You mean yours is SUPPOSED to look like that, right?
Yeah, that was a concern over there too.
Yes, mine is supposed to look similar to that but the square hole is almost round.
   / Stripped transmission drain plug - Ford 4100 #10
Oh, so you need a round peg for the square hole.
Hey, Peanut Gallery .... is this a candidate for welding? Piece of steel rod somehow, in the hole, then welded to the surrounding surface of the plug? Maybe bent like a lug wrench?
LMC G500-500A LOT IDENTIFIER 218 (A53084)
LMC G500-500A LOT...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2007 HONDA TRX250 RECON ATV (A51247)
2007 HONDA TRX250...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
