Stripped 445 transaxle drain plug
/ Stripped 445 transaxle drain plug #1
wcd30
Sperry Iowa
JD 445
Does anyone have a good fix for a stripped transaxle drain plug?
Hopefully at reasonable cost, and relatively easy?
Thanks,
Dave
/ Stripped 445 transaxle drain plug #2
Hi. Welcome.
I first would contact the dealer and see if they have an oversized plug that you can re-tap the threads and fix it that way.
Next I would get the next size bolt and a copper washer and re-tap the hole.
/ Stripped 445 transaxle drain plug #4
Shucks, were it me I'd tap next size up and simply install the appropriate plug to match whatever tap I'd used.
You do however want to use straight threads and not pipe thread but then most drain plugs should be straight thread and use a crush type copper gasket.
Problem with pipe threads is that they always want to leak just a little.
Were it me I'd want whatever matches the taps that I have on hand as the drain plug will be less costly than a new tap.
Heck get a plug from an auto recycle yard.
A drain plug does not care what engine or vehicle it is installed on.
Sure, a thread insert is a nice way to go but from experience also the costlier way and very necessary in some applications which IMHO a drain plug is not one.
To add, being on bottom, metal chips are of little concern as it would be very easy to flush and debris out.
/ Stripped 445 transaxle drain plug #7
Jeez, take the plug to O'Riley's, Auto Zone, Advance Store, etc tell them what happened and ask for the next size up oversize self tapping plug.
/ Stripped 445 transaxle drain plug #8
I used a self tapping oversized plug on a car oil pan. It was a quick fixand worked well.
2007 Kenworth T800 Tandem Dump Truck, VIN # 1XKDDB9X37J208917 (A65563)
2007 Kenworth T800...
John Deere 7000 4R Planter (A66408)
John Deere 7000 4R...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
2022 EZ-GO ELITE...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
Palp Cage for Chute (A66408)
Palp Cage for...
