Strange noise, hydraulic pump LK3054
/ Strange noise, hydraulic pump LK3054 #1
RADIATION
Kioti LK3054
Was working my tractor today, nothing out of the ordinary. 643hrs. 45°F.
I took the tractor down the road to another field. I was in 4th but wasn't running top speed. When I came back I heard this strange sucking sound. It only happens around 1100rpm.
Here is a video I took.
Any ideas?
/ Strange noise, hydraulic pump LK3054 #2
Tough to tell from video. Do you have the aluminum pump? Do you have pressure? Do hydraulics work? Wonder if pump is going bad? Any external leak? Did you check fluid level? I know the aluminum pumps were prone to failure. You can check with a magnet.
Unfortunately it is an aluminum pump.
/ Strange noise, hydraulic pump LK3054 #4
Have you serviced the hydraulic filter
/ Strange noise, hydraulic pump LK3054 #5
Sounds like cavitation.... check your suction screen. And piping to the pump
/ Strange noise, hydraulic pump LK3054 #6
I also believe it's cavitation. Probable cause is air leaking into inlet line, and/or restriction causing fluid to 'boil' on low pressure side of pump. Change or flush filter and inspect housing. Those little bubbles will erode the inside housing and gears of your pump. I had to change out my aluminum pump, but after 2000+ hours and I noticed the hydraulics were getting sluggish and weak. Your aluminum pump should last a long time once you figure out this problem.
Patrick
/ Strange noise, hydraulic pump LK3054 #7
I agree with others probably cavitation. But if you end up needing a pump they offer a upgrade for your tractor to 10 GPM Pump. I did that upgrade on my 2554 and it made all the difference in the world with my hydraulics. I can get you the part number if you need it.
I have changed the filter last year. I haven't used tractor much since. I'll service the hydraulics and see if it stops. K5lwq, yes i would like to have that number if it's not too much trouble. Thank you all!
/ Strange noise, hydraulic pump LK3054 #9
Here is a write up I did on my pump. Hydraulic pump.
The second post has the correct part number. Good luck!
Thank you!
/ Strange noise, hydraulic pump LK3054 #11
K5,
Any chance you'd still have packing list or complete part number list of pump, bolts, gaskets, etc.? My dealer does not seem too familiar with this upgrade.
/ Strange noise, hydraulic pump LK3054 #12
I would have to look. If I remember correctly the pump had the bolts and o-rings with it and I ordered them as well so ended up with extra.
If you call Michigan Iron they are familiar with the upgrade Kit.
I am on the road this week so will not be home till Sunday.
Update.
That noise is not coming from the hydraulic pump. It's coming from the power steering pump. I've seen one thread on here about the pump. There are no definitive details about what they used. Anyone replaced their pump or found a kubota substitute?
/ Strange noise, hydraulic pump LK3054 #14
Do you have a picture of the pump? I was not aware of a separate power steering pump on these.
/ Strange noise, hydraulic pump LK3054 #16
Okay, I am following you now. You only have the one pump for all of your hydraulics.
The first picture is of the priority/diverter valve. This is what feeds your power steering and front loader. It makes sure you have power to the steering first. It also contains a pressure relief valve that is bypassed when you have a loader installed by turning the diverter valve all the way clockwise. This looks like your setup.
The second picture would be of the power steering valve. It has it's own pressure relief valve on the side of it.
/ Strange noise, hydraulic pump LK3054 #17
I listened again to your video. It still sounds like cavitation but could just be from air getting into the system. Maybe look closely at the rubber hose that feeds the pump. If it is pulling air, it would travel to steering valve making a noise.
Awesome, thank you! I'll do some checking. It only does it if I drive on road. I own another property that takes me an hour to drive tractor too. That's when it's the worst.
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
Case SV280B (A60462)
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
1996 International Water Truck with a Caterpillar Engine (A61306)
1996 International...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2011 Volvo S80 Sedan (A59231)
2011 Volvo S80...
