David Devuono
Platinum Member
- Joined
- Nov 11, 2008
- Messages
- 847
- Location
- Brampton, On\lot Powassan, ON Canada
- Tractor
- Kubota B4200\MF 135\Kubota B3200
I have a 10 gallon tank with a 1 1/4 NPT suction line port. The available strainers drop the outlet to 3/4 NPT. Would it be better to stick with 1 1/4 suction line and leave out a tank strainer or move to a smaller line. Target peak flow is 15-18 GPM,
I probably already know the answer. So if it is to weld in a larger port flange, would a 1 1/2 in port with a strainer that has a 1 inch NPT outlet be large enough for my target peak flow?
My pump has a 20 ORB inlet. The issue I have with welding in a new port flange, the existing outlet has about 1" of threaded surface with which to seal with Teflon tape. The weld in port flanges have about 3/8 " of thread. Will I be able to seal this connection?
