stowing chain on my LS
   / stowing chain on my LS #11
I have a 4 inch cross tube on the FEL. Carry just about anything. Chain - shovel - plastic pipe - etc. Have two six inch chunks of plastic pipe that are capped. Shoved in each end will keep anything inside weathertight.
   / stowing chain on my LS #12
Since I have a ballast box mounted to my machine for most logging and yard work, I use my ballast box for storing hand tools and chain:
Chain usually sits in that top tray, with ends hooked to upper suitcase weight bar.
   / stowing chain on my LS #13
Lots of miscellaneous carrying options with the toolbox. I also made some tool racks that u-bolt to the ROPS for long tools. I try to not load really heavy items into the tool box due to working on hills constantly (high center of gravity), so still thinking about chain storage options.
   / stowing chain on my LS #14
I installed a grill guard and chain bucket combination. I carry a 20’ chain in the bucket below the grill guard. I also installed a steel toolbox on my ROPS cross brace where the useless plastic box was. I carry a 10’ chain in there.
   / stowing chain on my LS #15
For my use, it is the shorter chains that get the most use. I have at least four six foot lengths with a slip hook and a grab hook fitted to alternate ends.
If I expect to need a chain, I just drape one or more between the three grab hooks welded to the top rail of the bucket.
It does get cumbersome with the 16 foot chains however.
I need to drop size and up grade to 70! ;-)
   / stowing chain on my LS #16
As noted previously, a ballast box is a great place to carry chains, you usually need some extra weight there anyway. Here, you can see I have two 10-footers laying on top of the concrete in my box. I left the concrete about 2 inches shy of the top of the box, so I could use that space for carrying chains, hooks, and other tools:
On other occasions, such as when I'm not running a ballast box but still need a chain, I hang them from the front brush guard. You just have to be careful they're hooked securely and not dangling to the ground, since you don't want a chain getting under a tire and tearing off your brush guard.
   / stowing chain on my LS #18
here's what I built for my needs .
What did you use for end caps? Looking to make one for mine. I like the idea of flush caps so it can be pulled from either side.
   / stowing chain on my LS #19
I built a chain storage tray for the loader from PVC pipe just like the one in the above picture and used hockey pucks for end caps. They fit perfectly inside the pipe and I nailed them in with my small air nail gun.
2019 Harley Davidson (A56859)
2019 Harley...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
2010 FORD F-150 (A58214)
2010 FORD F-150...
2007 Ford F750 (A55973)
2007 Ford F750...
2016 FREIGHTLINER CASCADIA SLEEPER (A57880)
2016 FREIGHTLINER...
