Storing mower deck on its side
/ Storing mower deck on its side #1
linearxs
Northeast Ohio
Kubota BX2660
To make some room in the garage I decided to store the mower deck on its side. It's a 60 inch Kubota deck for a BX2660. I noticed today that it looks like oil is dripping out of it (slowly only a couple of drips over a month). I'm assuming it's gearbox oil. Would the gearbox leak if the mower deck is tilted on its side?
/ Storing mower deck on its side #2
Yup There is always a breather on gearboxes and they leak if turned over or on the side.
/ Storing mower deck on its side #4
Someone on here mentioned that the input shaft seal wasn't made to have oil pressing against it full time and would eventually leak if the deck was stored so that the input shaft was pointing down. This year I stored mine with the shaft pointing up and that also puts the vent on the upper side so maybe I killed 2 birds with one stone.
/ Storing mower deck on its side #5
Not always. My front differential on my Deere 4100 wasn't vented until I vented it.
That link showed what I'm seeing. Thanks. I do need to get an axle shaft though instead of putting all that pressure on the gauge wheels.
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
