Storing chains
/ Storing chains #22
Here is a unique thing that I put together for working with chains. It fits in a receiver hitch:
/ Storing chains #23
You people know how to make a guy feel like a slob with your nice neat shops. somehow I can never get there. I wonder if my chains would look that neat hung up instead of some on the floor of the one ton and and some of on the floor of the p/u and more draped on the winch plus a wood box full on the garage floor and another big box with 6 sets of tire chains.
gg
/ Storing chains #24
Here's a chain "shortener" for those that may have never seen or made one for themselves.
Ahhh Haaa - A new tool to build!
Anyone with ideas on a chain "lengthener"!!???
/ Storing chains #25
Yes, a chain with one hook.
/ Storing chains #26
Galvanized buckets, indoors, keep dry...Also makes it easy move chains around shed or to "work" by hanging bucket on convenient hook on tractor...
Agreed, This is the best way I have found. Easy to put the bucket on the carry all or in the back of the truck.
/ Storing chains #27
My two big chains are on the floor of my backhoe, right behind the seat. The rest are all in a 5 gallon bucket.
/ Storing chains #28
/ Storing chains #29
Chains are great in some places but I find using lift sling straps much easier for most jobs. They are light weight and don't scratch as much. A 2" strap will hold up 10 tons, more than I can pull.
Tom
/ Storing chains #30
Tire chains are heavy! I have two sturdy galvi nails hammered into facing studs. I hang the end crosspiece of a set of chains from one nail, then with a loud grunt put the other-end crosspiece on top of it. Then I do the same for the other set.
A couple of lighter nails on the outer edge of the same studs hold the only two tow-chains that I own. The longer one is doubled.
/ Storing chains #34
I cut a big opening in 1 gallon ~ liquid laundry soap containers.
/ Storing chains #35
been using this for years, just a peace of pvc pipe
That is a great idea!!
I may copy and mount the pipe on my 3-point tool carrier with the shovel and rake.
What is PVC pipe diam and length and what length of chain fits inside.
/ Storing chains #36
I believe that's a 3 inch pipe schedule 40 and I just cut it off to fit where I wanted it, I just held it up to the tractor and marked a spot to cut. just hang both hooks on the edge of the pipe. I think that chain is a 10 footer. Drill a drain hole in the bottom just in case you get caught in the rain.
/ Storing chains #40
I give all you people the thumbs up for great ways of storing chain;)
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2010 Case 580N (A60462)
2010 Case 580N...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
