Storing chains
/ Storing chains #3
been using this for years, just a peace of pvc pipe
/ Storing chains #4
Tire chains or tow chains?
Tow chains it varies,
I usually keep one on the floor of the cab,
if I'm going some were to use a chain I will ofter loop it around the 3 point,
normal storage has some coiled up in the corner of the shop floor,
usually one or two on the trailer,
often one in the box of the pickup.
/ Storing chains #5
I cheat. My backhoe has a cab. (no windows though, but don't ask!)
I just clump my 25 foot grade 100 chain on the floor in the rear corner. Always out of my way and easy to get to and always with me. Don't know how I'd attempt to keep it with the tractor. Probably have to make some kind of box or something that's attached to the ROPS.
/ Storing chains #7
Galvanized buckets, indoors, keep dry...Also makes it easy move chains around shed or to "work" by hanging bucket on convenient hook on tractor...
/ Storing chains #9
Chains on horizonal 2" pipe stood of wall 18" , 3' above floor. Come-a-longs and ratchet straps on horizonal 2x2 angle iron stood off wall 6" about 1' above chains. Additional small ratchet straps and bungees on 2x2 angle iron stood off wall 2" about 1' above come-a-longs. Ropes and cables on hooks above bungees about 6' from floor.
So that I can identify those that jump down,walk away and find a home in other people's stash,I do this to hooks,ends of chain and handles. 2 coats of aluminum spray paint + 1 coat of white paint topped off with 2 coats hot pink fluorescent paint. It wear's off but after 20 years plenty remain's inside links and where there's no abraision. The first 4 or 5 years it glow's in dark. The small amount remaining after 20 years still make's it much easier to find when miss placed during use in the field.
/ Storing chains #11
That is one heck of an organizational mind to have something so neat and functional. Very impressive.
If you think that's impressive,check this out.
/ Storing chains #12
Hand the on hook spray them down with WD40.
/ Storing chains #13
I got a couple baskets on a loader tractor and hook up a bunch of stuff as free additional counterweight for the forklift.
/ Storing chains #16
There goes Terry, showing everyone up as usual! What an apple polisher! 😁
I don't have too many chains so I store them in 5 gal buckets with the hooks on the rim kept next to each other from each chain so you can find them easily. As long as you don't fill too much, they are portable.
/ Storing chains #17
I only have a few chains; most are 100 year old, they were used to control the rudder in an old ship I bought.
Anyway, I made steel pegs and drilled a solid concrete section of my shed wall, they pounded them in.
CHEEEEP!
/ Storing chains #18
That is just beautiful. Note the safety chain with the spring closure right of center and the very old drawbar clevis top right. Look at the dual purpose slip and grab clevis top left. Never saw saw one like that.
/ Storing chains #19
2018 Club Car Carryall 1700 4x4 Utility Cart (A61572)
2018 Club Car...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Generator (A61572)
Generator (A61572)
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
Case SV280B (A62177)
