STORING ATTACHMENTS
   / STORING ATTACHMENTS #41
That's my current (but not yet started) project. Keep us updated! (please) :cool:
Anybody have opinions on whether the wooden or automotive (shown) dollies are superior? I am using the wooden ones for my land plane and am wondering whether the ones shown above are superior. Does more expensive = better? :laughing:
I use both wooden that I have built and the car dollies.The trick IMHO to the build on the wood dollies they have to be built stout with good wheels that rotate 360 degrees.
   / STORING ATTACHMENTS #42
Wood works! I had one heavy duty castor that is a inch and a half shorter than the other two, so I made a "Tee" out of 2 by's.
The tree puller weighs 284 pounds.
   / STORING ATTACHMENTS #43
Made my first attachment dolly. Guinea pig was the bucket from the FEL. I'll give it a couple weeks to see how well it continues to work, and if it needs any tweaks. Then I'll do the rest.
Thanks to everyone in this thread, some great ideas and pics!
   / STORING ATTACHMENTS #44
All the ideas are great and worth considering a old man who has sinced passed had a lean to shed that he put his equipment under he took and figured where the best lift point was for each one and bought cheap comealongs and on the beam under his shed he attached a comealong to the balance point of each attachment this was before quick hitches he would lift say bush hog a little off ground and was able with little effort move it around as he needed to hook it up
   / STORING ATTACHMENTS #45
Sounds like a good approach, Rocky
David Sent from my iPad Air using TractorByNet
   / STORING ATTACHMENTS #46
I store the chipper and ballast box on dollies in the garage. The mower (RFM) stays on the tractor all mowing season...which is also in the garage. The snow blower is stored on blocks (6x6's) in a dirt floor shed...until winter (then I swap the RFM for the blower). The loader also stays in the shed until winter, unless I have need for it during the mowing season.
The cutter stays outside on 4x4's. I don't tarp it during the summer months, but I will cover it before the first snow.
Most important thing (IMHO) is to use Fluid Film on exposed metal surfaces to keep the rust away.
   / STORING ATTACHMENTS #49
I just now found this thread, but since we got our barn floor poured cured, and sealed, I have been making implement (and compressor, and wood rack, and tool stand) dollies from pallets and scrap wood using casters sourced variously from other rolling fixtures, garage and barn sales, a hospital dumpster (I really miss the swag from that job), HF, Northern Tool, TSC, MCM, Grainger, and whereever else I can source decent quality casters for as cheaply as possible.
So far all have worked well, because I am careful to index the capacity of the casters to the approximate weight of the item to be stored on it.
There is one case how ever that I did not do a good job of matchimg the casters to the item, and that is actually one of the smallest pallets I used (an approximately 2'x2' square), under which I used the same casters (rated at 150# each) that I also used under the 5'x 2.5' pallet/platform we put our 4' Gannon ROBB on, which rolls easily.
Have you guessed what small, yet dense and heavy implement I underestimated the weight of yet?
It is the "Kubota-branded" ballast box we loaded with steel disk brake drums and other scrap metal and concrete, hoping to get it to a weight of something a little over #500 because that is what the label on it recommended. Apprently we over shot that at least a bit :)
I have some bigger casters from one of the more industrial sources, and I will be making a new small platform cart for the BB.
The one implement (or probably more accurately attachment) that we won't be storing this way is the 60" MMM, because it seems like it would be more efficient to store it on edge, whether vertically or horizontally.
The 3-point boom, being very sturdy, durable, non-mechanical, non-hydraulic and already rusty because we bought it used, will be ignominiously stored outside in the weather.
   / STORING ATTACHMENTS #50
I'm also interested to photos of backhoe dollies....
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A55788)
2005 Isuzu NPR...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2018 SOLAR TECH SILENT MESSAGE / LIGHT BOARD (A52705)
2018 SOLAR TECH...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A55787)
2025 GIYI Stump...
