Stone Driveway over Sand
/ Stone Driveway over Sand #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
I need to know what type of stone material would work best for a stone driveway around 250' x 12'.
As is common in Florida my soil is very sandy and I am looking for some type of stone material that would be suitable over the sandy soil.
Also, what the best way to prepare the sandy soil before putting the stone down?
Thanks.
/ Stone Driveway over Sand #2
To compact sand and crushed gravel you need a vibratory packer. Small self propelled roller ones that fit the back of a P/U can be rented should work.
Whatever stone you use make sure it is crushed so it can be packed.
Egon
/ Stone Driveway over Sand #3
I would mix the stone into the sandy soil to a depth of 8" or so. Then smooth and roll out. The driveway will be much better if you mix the stone with the sand than just try to put stone on top. The sand underneath will still be able to shift. You can put a coating of stone on top after you have a good base, but the drive will only be as good as the base it.... Besides, it will give you more seat time.... /forums/images/graemlins/grin.gif
2001 Ford F-450 Super Duty Flatbed  7.3L Power Stroke Diesel (A63688)
2001 Ford F-450...
2003 Tennant 7400 Compact Industrial Floor Scrubber (A61572)
2003 Tennant 7400...
(5) BURNER WARMER 220 (A64281)
(5) BURNER WARMER...
BALDOR INDUSTRIAL 15 HP MOTOR (A64281)
BALDOR INDUSTRIAL...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
