Stone base
   / Stone base #1
Mac25
Danville, IN
Kubota B2320 HST with LA 364 FEL
What is the consensus on the best stone base to use for concrete? I was going to use 53's with dust and compact it.
Sent from my iPhone using TractorByNet
   / Stone base #2
Need more info. Are you placing a slab for a heated or non heated building? Or are you paving aprons sidewalks or driveways? What is the subsoil type and drainage?
   / Stone base #3
If going over stable compacted sub base, we use #78 gravel here, as it's easily raked and self compacts.
   / Stone base #4
Numbers for stone are different in different parts of the country.
I like what we call 57's. Which is ~3/4" screened. And I like it in the limestone variety and not gravel. It locks in well, and goes farther per ton than the stuff with the dust.
   / Stone base #5
My last contractor likes to use a crushed limestone that is 3/8 inch and without the fine dust. It grades as easy as sand and after compacting it is hard to disturb.
I think using a product with the fine dust would impede water movement, when water get under it.
   / Stone base #6
3/4" screened stone with clean sand added to chink it works well. It makes a strong base and is free draining. The stone dust mixtures hold water and can cause frost problems. If ground water is a problem or the subsoil is organic (black and mushy when wet) Cut out a couple of feet more and back-fill with bank run sand or gravel then cap with a stone base top layer.
Adams 16T Tender Body (A55301)
Adams 16T Tender...
TORO MBTX2500 STAND ON DUMP BUGGY (A52705)
TORO MBTX2500...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
UNUSED LANDHERO T-TOP & WARNING BURTINGS (A54757)
UNUSED LANDHERO...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
