Stihl low on power
   / Stihl low on power #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
My 025 Stihl chainsaw seems to be low on power. I am having problems cutting logs that it used to zip through. I put a new chain on and it's still not cutting well so it's not just a dull chain. Even though it starts easily and sounds like it always has, the engine appears to be running hot. There is smoke coming from under the chain cowling. I am thinking about one of two options. Either take it too a service center and have it serviced or just get a new one. I am worried about a large repair bill and not being satisfied with the results and then going on and getting a new one anyway. What would you do?
   / Stihl low on power #3
Was it going fine when you first started to use it that day but just seemed to de-power after a little while?
   / Stihl low on power #4
The muffler is probably fouled with oil.
   / Stihl low on power #5
How fresh is the gas ?
   / Stihl low on power #7
Replace the fuel filter, air filter and the spark plug. Also as suggested check the muffler, you could also take the muffler off and check to see if the Pistons scored. But definitely put new fuel in it as you might have a bad batch. (Make another batch)
   / Stihl low on power #8
Chain brake hanging up?
   / Stihl low on power #9
Chain oiler is my guess. Bar gets hot and expands causing chain to become so tight that engine can't turn it.
   / Stihl low on power #10
Make sure you have 2 stroke oil in gas.
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
UNUSED FUTURE FT-X-DM43 43" HYD DISC MULCHER (A57193)
UNUSED FUTURE...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
UNUSED FUTURE VR59 59" HYD VIBRATORY ROLLER (A57193)
UNUSED FUTURE VR59...
UNUSED 1RANCH 1RET13 HIGH END ELECTRIC TRICYCLE (A57192)
UNUSED 1RANCH...
JLG 1255 Telehandler (A55315)
JLG 1255...
