Stihl chain saw with malfunctioning brake
   / Stihl chain saw with malfunctioning brake
Check out the rest of the mechanism in there and the sprocket on the clutch while you have it apart. Get all done at once.
Clutch sprocket looked good as did all the rest of the brake mechanism. The one thing I did question is the needle bearing between the clutch shaft and drive sprocket bell was bone dry. I'm assuming here that just a little grease on the bearing is better than none at all.
   / Stihl chain saw with malfunctioning brake #12
Yeah you would think bone dry is not so good. Bar oil wouldn't be able to work it's way into there either. Too much grease could get caked up with crud as well.
   / Stihl chain saw with malfunctioning brake #13
A little grease is good. That only spins at an idle.
   / Stihl chain saw with malfunctioning brake #14
With the brake off, lift the brake band assembly out of the case. Install spring and put the brake band back in.
I'll give that a try once the spring arrives, thanks.
It's one of the easiest starting chainsaws I have ever used, and I have worn out a few x-brand models before stepping up to Stihl.
   / Stihl chain saw with malfunctioning brake #18
Opps. Disregard that advice. I just put my 260 back together. The brake band doesn't tension that spring.
Looks like some vice grips and muscle are the answer.
2251 (A58376)
2251 (A58376)
1987 Chevrolet R3500 (A57148)
1987 Chevrolet...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
New/Unused 8 Piece CFG Industrial Mini Excavator Attachment Set (A57454)
New/Unused 8 Piece...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
2019 Bomag BMP 8500 Trench Compactor (A57453)
2019 Bomag BMP...
