Stihl chain saw with malfunctioning brake
   / Stihl chain saw with malfunctioning brake
Check out the rest of the mechanism in there and the sprocket on the clutch while you have it apart. Get all done at once.
Clutch sprocket looked good as did all the rest of the brake mechanism. The one thing I did question is the needle bearing between the clutch shaft and drive sprocket bell was bone dry. I'm assuming here that just a little grease on the bearing is better than none at all.
   / Stihl chain saw with malfunctioning brake #12
Yeah you would think bone dry is not so good. Bar oil wouldn't be able to work it's way into there either. Too much grease could get caked up with crud as well.
   / Stihl chain saw with malfunctioning brake #13
A little grease is good. That only spins at an idle.
   / Stihl chain saw with malfunctioning brake #14
With the brake off, lift the brake band assembly out of the case. Install spring and put the brake band back in.
I'll give that a try once the spring arrives, thanks.
It's one of the easiest starting chainsaws I have ever used, and I have worn out a few x-brand models before stepping up to Stihl.
   / Stihl chain saw with malfunctioning brake #18
Opps. Disregard that advice. I just put my 260 back together. The brake band doesn't tension that spring.
Looks like some vice grips and muscle are the answer.
2016 Chevrolet Traverse SUV (A55853)
2016 Chevrolet...
202481 (A54757)
202481 (A54757)
1779 (A51248)
1779 (A51248)
Kubota RTV900 4x4 Utility Cart (A55851)
Kubota RTV900 4x4...
1992 Ford LT9000 T/A Day Cab Truck Tractor (A55852)
1992 Ford LT9000...
2010 INTERNATIONAL LF627 SLEEPER (A56138)
2010 INTERNATIONAL...
