Stihl 036 scored piston?
   / Stihl 036 scored piston? #11
Wether it needs just a piston and rings, or a cylinder as well, its all pretty easy and straight forward. Its not often that the crank bearings and seals need done. They are pretty resilient.
Get it appart and get us some pics of the exhaust side of that cylinder:thumbsup:
Getting it apart is becoming "interesting". I had to walk away from it last night. Too many biting bugs, not enough light and patience running low. Not a good recipe for doing it right. Will consult manuals before trying again.
   / Stihl 036 scored piston? #13
Dont be afraid to ask questions and/or post pics of what you are having trouble with. For me, the absolute hardest thing is getting the little cir-clips out of the piston to take it off the rod.:mad: But that is after you already have the cylinder off.
It also helps to use an air-compressor and get everything CLEAN before taking off the jug. You dont want all that crud to fall down in the crankcase. And if you already have the carb off, make sure you either stick a rag in the intake or make sure the piston is blocking the port before you clean it with compressed air.
   / Stihl 036 scored piston? #14
Even though it looks straight gassed. I would still check the seals, rubber intake, etc for a source of air leaks. Check those bearings too, even though probably nothing wrong with them. Better safe then smoke another top end or piston.
I just redid a 036 pro and it's back at it. Good Luck.
That fine sawdust/bar oil "mung" was part of my frustration the other night. I'll take the compressor to it before
I do any more tear down. I got hold of the repair manual, last night, and started to study it - $4.95 well spent!
It shows 4 bolts that are accessed through deep holes in the head, that I completely missed seeing in my initial
tear down attempt.
Thanks for the tip, xyz123. I will definitely check the bearings and for air leaks. Since I don't know why the piston got scored in the first place, I'd like to eliminate as many possible causes before I try to fire it up again. Since I don't really need this saw I can take my time with it and wait for any parts I may need.
   / Stihl 036 scored piston? #17
tear down attempt.
Yep. I assumed you knew this. Those bolts are all that hold the cylinder (jug) on the crankcase. After the carb/intake and muffler is off, take those 4 bolts out and the cylinder just slides off the piston.
A couple of other notes:
1. Sometimes there is an anti-vibe mount that connects the cylinder to the handle. That needs removed as well.
2. You dont always need to remove the top-handle, but it makes things soooo much easier getting the jug off.
3. Most everything on saws is T27 torx. At least on the huskys and dolmars and few stihls I have worked on. You need a good one and not an el-chepo one for them 4 jug bolts because sometimes they are a PITA and really tight.
4. Final note, once you take the jug off, wether you decide to re-use or get a new one, look at the bottom of the cylinder and see if it is beveled. This helps on re-install so you dont snag the ring. If it is not, you can either bevel it, use a ring compressor, or just work it in with about 3 hands/fingers. But either way, if it isnt beveled (or beveled much) just be aware of it upon re-install.
   / Stihl 036 scored piston? #18
Should have ask, I could have gave you one free. I have a IPL and service manual request sub-forum on chainsawrepair.
I am so going to keep this in mind!
Okay, got the jug off last night after some difficulty. The long series of holes through the fins on the jug/head were misaligned with the bolts and almost exactly the same diameter as my Stihl torx scrench - so the bit wouldn't engage the bolts. Typical, shoddy German engineering! Sorry, as an American engineer, I couldn't resist...
Had to open up the holes in 2 locations with an N sized drill to seat the bit:
Wear in the jug doesn't look as bad as I was anticipating. i was thinking about trying to remove the smeared aluminum using the muriatic acid trick, but saw a good sized pit/spall started on the exhaust side, down low (near the top of the photo, close to the chamfer & flange):
Piston & rings are toast:
Time for a new sprocket:
Clutch side looked oily & wet, so I'm going to give the seals a good looking at:
Once I get the clutch apart - more reading for me.
The crank bearings seem tight, turn smoothly and with little effort, so that was good news.
So far it looks like I'm getting a new sprocket & spark plug, a new jug & piston.
New impulse tube & fuel line.
What else would I be foolish not to replace, now that it's torn down?
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
2023 Jeep Gladiator Pickup Truck, VIN # 1C6HJTAG5PL542594 (A57453)
2023 Jeep...
Katolight SED60FJJ4 60kW Towable Diesel Generator (A56857)
Katolight...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2022 Takeuchi TL12R2 (A55272)
2022 Takeuchi...
