Sticky clutch 2N
   / Sticky clutch 2N #1
2Njohn
Kansas
1945 2N
I am finally going to split the 45 and take care of the clutch. I know it sticks because of the rear main seal leaking oil on the disc and engine oil is dripping out of the weep hole under the clutch. I just looked at just 8ns for parts, assuming the disc is okay would I need anything more than rr main seal and a trans input seal? It has a Sherman stepup, step down, any seals on that to deal with while in there?
Clutch holds great so I plan to just give it a good cleaning and reinstall. Probably put a new starter drive on since mine kicks out occasionally. I heard it is easier to do with the tractor apart.
   / Sticky clutch 2N #2
if I was opening her up and had to split her.. no way i WOULDN'T put in a new clutch.
since your tracgor doesn't have a standard input shaft.. but DOES have a sherman combo, that has a nose of the same dimensions as an input shaft.. wanna bet where that input shaft seal goes? ;)
ps.. bet on the clutch being oil soaked and ruined... (I would...)
   / Sticky clutch 2N
Good advice, clutches are at least very cheap for these N's.
Went to start it last night to pull it in the shop and after about 10 revolutions of the engine the starter just quit. It did it once in the summer and after checking all connections and cleaning them with no luck, I was only able to start it by jumping it off a 12 volt vehicle. After I did that the starting system worked again, I hope I can get lucky again and be able to jump it tonight.
   / Sticky clutch 2N #4
i'd look for dirty cables ort bad connections. or weak battery. lastly, a bad manual push switch
   / Sticky clutch 2N
I jumped her with my old pickup and brought her to the garage she ran fine. Pulled the pushbutton starter out and that mechanically worked fine. I have focused on the switch with two bolts and two battery cables hooked to it, maybe the contacts are shot.
The condition of the battery cables overall are poor at best, I cleaned the connecting points with a bench grinder wire brush a few months ago so they were still all okay.
I will try and post some pictures, seems it is not possible using my iPhone. image.jpg
   / Sticky clutch 2N
Ha, I figured out to post a picture but they are not right side up....
   / Sticky clutch 2N #7
grease the contacts and bat posts / cables.. keeps em corrosion free longer.
low current from bad connections burns the contacts inside the big start switch..
   / Sticky clutch 2N
Yep I went to town and bought 3 new battery cables and some goop for the terminals. Big switch is shot will call and order one from stevensons on Monday also need to get the clutch coming.
   / Sticky clutch 2N #9
cool.. you won't regret the clutch.. one split and you are good...
   / Sticky clutch 2N
I have the ford manual... And am wondering what is involved in replacing the rear main. Do I drop the oil pan? Tips for a you bet you butt no leak install?
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
7046 (A50322)
7046 (A50322)
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
