Steps for an X1100C?
/ Steps for an X1100C? #1
mmancuso13
Sykesville, MD
Bobcat Toolcat 5600, Kubota RTV-X1100C
Hey all, has anybody added aftermarket steps to their X1100C?
My wife is short and needs some steps added to help her get up into the cab.
While we are on the subject has anyone welded in a hand grip on the drivers side like they have on the passenger side?
That would seem better than using the steering wheel grab all the time?
Thoughts?
And thanks in advance!
/ Steps for an X1100C? #5
I added a step to my old 1100 for my wife. Took it off when I traded it in for the x1100. It worked just fine but had to watch clearance over large rocks. I still have it if you want me to take a pic of it?
Yes please, thank you.
My concern is the mounting. Did you weld directly to the underside frame rail?
And did you use a small truck or jeep step and adapt it?
/ Steps for an X1100C? #7
The step is from a Kubota tractor. It is one these hoop types that bolt on. Drilled mounting holes into existing support straps on the underside and bolted it on. Works very well and sturdy
/ Steps for an X1100C? #8
Here is a pic of the step
/ Steps for an X1100C? #9
That looks similar to my Deere one I put on my 2720. It is about 10.5" wide with a 5.75" drop and about 3.5" offset. The deere part number is LVU18332.
Thanks! I will have to fab up some type of mounting brackets to weld on to the outer frame rails to give me a place to bolt on steps.
The underside of the X1100C has the inner box frame but it is too far in to be useful. The outside rails are quarter round with a notch shaped and the unit has almost full coverage with underside pans. There is simply no place to bolt anything...
/ Steps for an X1100C? #12
I looked at my x1100 and bolted in two 10 inch lengths of 2 inch angle iron and bolted the step to the angles. Did not have to weld anything
/ Steps for an X1100C? #13
here are some pics
/ Steps for an X1100C? #14
/ Steps for an X1100C? #15
Yes it is flexible for sure. However it needs hang directly under the front edge to work best
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A59914)
2015 ALTEC AT200...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNGK26K97G305720 (A65563)
2007 Chevrolet...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
