Stepped off, and it almost tipped over (lifting a snowmobile) !
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #21
Maybe you should have had the hoe on. ....It is scary when it does happen, thanks for the photo.
tractor-with-missing-wheel.jpg They can add some counter-weight, but you shouldn't talk like that. :laughing: :rolleyes:
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #22
Sodo, Thanks for the picture. :) Every time I get into a near roll/tip over situation my 20/20 hindsight kicks in. :eek: From now on I will always have my tractors set up perfectly for any job I have to do. ;) yeah right.
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #23
The picture is something we seldom see and can help a lot of people understand what happens before the machine tips. Really glad it all worked out fine and other can learn from it.
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #24
I sure hope the naysayers view this. As all can see from the photo, it is a long way from tipping over when the front axle hits the stops.
I have been trying to tell folks that the front axle does help in tipping situations but all I get is, "IT swivels and by the time it hits, it is too far gone" Well this photo proves that it isn't too far and the front axle definitely does help prevent a roll over. Putting ballast in the front tires would certainly help also.
I agree with your premise. The front axle stops certainly do provide a resistance to tipping over. but would like to make a correction to the way you state it. How far away from tipping over it is when the front axle hits the stops depends on both the speed of the tip and how much of an unbalance exists. In other words, the momentum that the tips has. If you're only slightly unbalanced, and the tip is slow, then you might very well just end up like the picture. But there are certainly conditions under which the resistance offered by the front axle stops isn't going to prevent a tip-over.
xtn
Glad you made it out safe and sound....and thank you for taking the pic.:thumbsup: On a scale of 1-10 what was the pucker factor at???:laughing:
Higher when it was moving?less when I realized it was stable.
Clearly the pucker factor was not high enough to cause him to lower the sled to the ground and remove himself, his tractor and his sled from impending danger. The Darwin Principle missed out on a statistic here. Taking time for a pic in these circumstances is just plain dumb.
I started to step off (to take a pic) and my weight leaving the tractor started it to tip. I leaned out to try to stop it but it kept going, until it came up against the stops on the front axle WHEW!. Was just about to throw the FEL down, which would have dropped the snowmobile.
I sat there for a moment realizing it was stable, and then carefully stepped off completely because now I HAD to take a pic. I pushed on it a little to confirm it was stable, and it was, so I quickly took a pic and climbed back on, and lowered the loader very very slowly, and the rear wheel came down.
Besides, I got off on the high side, Darwin statistics would get off on the low side (sometime prior to reproduction opportunity). I know what you're thinkin' Rick, and NO I was not dumb enough to show this pic to my wife.:laughing:
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #26
Man, I feel responsible for asking for action shots... but for all those preaching about how stupid you were, I want to know if they ever did anything stupid on their tractors? At least you were man enough to admit it and have the pic to prove it! :laughing: I will admit getting myself in a pickle or three with my BX but I haven't posted a pic.... yet. :eek:
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #27
. but for all those preaching about how stupid you were, I want to know if they ever did anything stupid on their tractors? and have the pic to prove it! :laughing:
Sure I have; stupid, dangerous, reckless. But I don't recall stopping in mid-event and waiting for things to get worse!
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #29
Thanks for the pics and all the constructive comments that were made in reference to this type of situation . It makes one think what could have happened , I have tipped my 5700 just slightly a couple times and gets your attention real quick .
   / Stepped off, and it almost tipped over (lifting a snowmobile) ! #30
Well for gods sake, get off and take a few pics next time...lol;)
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
