Step for the right side of a Kubota L2800
   / Step for the right side of a Kubota L2800 #1
teg
Super Member
nowhere
s
First off... this was a simple and easy thing to build (ok really super simple compared to the rest of the stuff on TBN ;)) I wanted to build the step for a while that may protect the HST filter (a little).
I get on and off from the right side more than I should... the FEL joystick was a little in the way so I cut it down 8" and although it's harder to feather it, I'm used to it and like it. I had spare bolts and some scrape steel that I used, IIRC, 3" angle that was 3/8" (?) thick.
I used the holes in the FEL loader mount to bolt a 6" piece that was flush with the bottom. Then used a longer piece (?) that I notched and bent to bolt up to another hole in the FEL frame at an angle. Once the two pieces were bolted I clamped and welded it only on the topside, I used AC-6011 1/8" @ 135.
I liked how it doesn't flex, I plan to trim off or round off the edges but wanted to use it for a while as is. I would notch the step back if I were to do it again (see the last photo).
   / Step for the right side of a Kubota L2800 #2
I added a right side step to my TC 55 when it was delivered. I cheated and removed the right side step off the TC45 I traded in. Matches perfectly, no welding or painting.
   / Step for the right side of a Kubota L2800 #4
Nice job Teg,, good thinking. That should work well:thumbsup:
you know I hate to say this... no I wont't say this, well I should not say this.. ...
my Kioti has a step on the right side..:eek::eek::eek:
All in good fun:thumbsup:
James K0UA
   / Step for the right side of a Kubota L2800 #5
Haha. So does my cub cadet.
Honestly, loader joystick or not, who the h3ll is only going to ever get off their tractor on the left side only? I get into tricky situations in the woods all the time where its actually easier to go through the operator station than around the tractor, haha.
...you know I hate to say this... no I wont't say this, well I should not say this... my Kioti has a step on the right side.....
Serious If I were to buy again, it will be the other orange (most likely). Sorry to see you leave the jerky hitch club :D If I was an actual member ;) I would have sold out too :laughing:. And to think I thought no one saw this thread :p
Beats me, too. It's not a horse!!! I have a feeling I'm going to use this step a lot... Maybe since it's an economy model they couldn't afford to put a step on the other side!!! :mur:
   / Step for the right side of a Kubota L2800 #7
Only one step? Thats like a cab without 2 doors !!! The new 5083e comes with one door .. the second is an option.
Nice job on the step!!!
Paint??!! What's that? :laughing: ...and it's not a project without welding. Wish I can figure out more welding projects :thumbsup: Thanks for the comment (thought no one was going to make a comment :p) I would have been happy with comments like... "my sister can weld better then that!!!"
   / Step for the right side of a Kubota L2800 #9
I think it is great.. But my massive 175 lb posterior and anterior elements may create a crack larger than my posterior element desires to have....
:laughing:
I think it is great...
Hey "Jackson"... :D if it can hold my fat arse... well, haven't been up to use the step for over a month... stupid j.o.b. is getting it the way of my tractor time :( How's your L3400 hanging?
2010 Ford F-150 XL (A50120)
2010 Ford F-150 XL...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
Ford F800 (A50121)
Ford F800 (A50121)
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Satoh Beaver Tractor (RUNS) (A50774)
Satoh Beaver...
