steiner 430 max kohler gas back fire help
/ steiner 430 max kohler gas back fire help #1
Branson107
Steiner 430 max kohler 2002
Steiner 430 max kohler gas tractor , my dad was cutting the grass and it backfired now it won’t start , change the fuel pump , still won’t starting , any help or suggestions would be greatly appreciated
/ steiner 430 max kohler gas back fire help #3
I would look closely at the key stock between the crankshaft and flywheel. Most likely it has sheared.
/ steiner 430 max kohler gas back fire help #4
The above suggestions are probably good. If you changed the fuel pump disconnect the output side and be sure it's actually pumping fuel. Some new pumps are defective right out of the box. That was my most recent Kohler experience.
ok i will check that ,
i am not sure what that is but i will look and see if i see anything
/ steiner 430 max kohler gas back fire help #8
Not the best picture but this is a screenshot of the service manual for the engine. I put a magnifier over the key on the crank shaft and circled in red where it talks about inspecting it. You have to remove the flywheel to see if it is sheared.
ok thank you so much
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
2024 MECO M-Y 4-Passenger Electric Car (A59231)
2024 MECO M-Y...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
