Steiner 220 Engine RPM ?
/ Steiner 220 Engine RPM ? #1
steiner220
Steiner 220
Hi!
I'm writing for the first time in this forum.
I describe my concern:
I bought Steiner 220, the engine was dead.
In Estonia, where I live, unfortunately, Steiner is not a common machine and no technical assistance.
I bought a new used Kubota D600 engine, which was used earlier on a rice harvester.
The RPM and fuel in this new engine are likely to be smaller.
How much should the engine rpm be when I measure them on a flywheel. I mean rpm when the speed lever is max.
I want to adjust the speed lever so that when switching to the maximum, the engine does not break.
Sorry for my poor English. I speak Estonian every day.
Greeting
Sander
/ Steiner 220 Engine RPM ? #2
You did not say what the original engine was, but appears all engine options are rated at 3600rpm @ wide open throttle.
The D600 will have no problem although you may have to adjust the throttle stop if the original application used a lower RPM.
Hi,
I set the engine max 3000 rpm, no more daring because the sounds were already very loud. I hope 3000 rpm is enough and not breaking the engine.
Sander
/ Steiner 220 Engine RPM ? #4
Hi,
Sander
The D600 is designed to run up to 3600rpm all day long and was set to 3600 when used in the Steiner 220.
