Steering
/ Steering #1
freetrapper
Urbana Mo.
None
Need to rebuild my power steering cylinder, one parts sight says their kit only fits new style, two others do not ask new or old so my question is, do I need to order for new, old, or does it matter witch since the only difference seems to be the port sizes and they are external.
/ Steering #2
Welcome freetrapper.
I think it would help you to know what year your tractor is, and what port sizes you have. That will determine which kit you want to get.
/ Steering
Hi Bob, Thanks for getting back to me I know its a 2003-04 254, I haven't taken any lines off as yet had to finish a job before tearing it down will check fitting size tomorrow.
/ Steering
Ok, a couple days late I got side tracked I know it says 2003-4 forthe year and the ports are the 13.5 mm makes it an old style, am going to do the 3 point lift while I have it down need a rebuild kit for it as well. Can any one help with part numbers or who to call to get the kits.
/ Steering
Update on steering, called Tommy at affordable he was most informative knows his Jinmas, got everything coming that I need including the three point rebuild kit. Thanks Tommy you will definitely be my sorsce for parts.
2012 KENWORTH T800 TRI-AXLE (A67714)
2012 KENWORTH T800...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2008 THE MACHINE CO. THAWZALL H250 HEATER  (INOPERABLE) (A68842)
2008 THE MACHINE...
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
