Steering
/ Steering #1
freetrapper
Urbana Mo.
None
Need to rebuild my power steering cylinder, one parts sight says their kit only fits new style, two others do not ask new or old so my question is, do I need to order for new, old, or does it matter witch since the only difference seems to be the port sizes and they are external.
/ Steering #2
Welcome freetrapper.
I think it would help you to know what year your tractor is, and what port sizes you have. That will determine which kit you want to get.
/ Steering
Hi Bob, Thanks for getting back to me I know its a 2003-04 254, I haven't taken any lines off as yet had to finish a job before tearing it down will check fitting size tomorrow.
/ Steering
Ok, a couple days late I got side tracked I know it says 2003-4 forthe year and the ports are the 13.5 mm makes it an old style, am going to do the 3 point lift while I have it down need a rebuild kit for it as well. Can any one help with part numbers or who to call to get the kits.
/ Steering
Update on steering, called Tommy at affordable he was most informative knows his Jinmas, got everything coming that I need including the three point rebuild kit. Thanks Tommy you will definitely be my sorsce for parts.
2022 EZ-GO ELITE...
1999 38ft Beverage Trailer (A65563)
1999 38ft Beverage...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
500 gal Poly Fertilizer Tank (A66408)
500 gal Poly...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
