STEERING WHEEL on PT-422 (2003)
   / STEERING WHEEL on PT-422 (2003)
Man! Ugh!
I got the new roll pin and installed it into the steering shaft. Put everything back together AND THE TRACTOR WOULD NOT START!
Ya got to be kidding me. It was as if I had a dead battery (its new, and I check it with a meter.)
I was going to check the Key Switch (maybe it went bad) but it does not have ANY letters on it or the terminals/prongs, so I don't know which prong is G / B / M (ground / battery / magento) etc.
Plus it is a 6 prong. 1 prong at the side of the circle, then 1 in the middle at the top, then 2 under the 1, and 2 under the 2, for a total of 6 prongs.
Does anyone else have this type of Key Switch?
   / STEERING WHEEL on PT-422 (2003) #32
Maybe you bumped your PTO switch. Check that before you do anything else. It won't start or do anything if that switch is flipped to the ON position.
2007 International 4300 (A53314)
2007 International...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
48ft all aluminum feather light wedge trailer (A56435)
48ft all aluminum...
UNUSED FUTURE...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
