STEERING WHEEL on PT-422 (2003)
   / STEERING WHEEL on PT-422 (2003)
Man! Ugh!
I got the new roll pin and installed it into the steering shaft. Put everything back together AND THE TRACTOR WOULD NOT START!
Ya got to be kidding me. It was as if I had a dead battery (its new, and I check it with a meter.)
I was going to check the Key Switch (maybe it went bad) but it does not have ANY letters on it or the terminals/prongs, so I don't know which prong is G / B / M (ground / battery / magento) etc.
Plus it is a 6 prong. 1 prong at the side of the circle, then 1 in the middle at the top, then 2 under the 1, and 2 under the 2, for a total of 6 prongs.
Does anyone else have this type of Key Switch?
   / STEERING WHEEL on PT-422 (2003) #32
Maybe you bumped your PTO switch. Check that before you do anything else. It won't start or do anything if that switch is flipped to the ON position.
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
