steering wheel nut, MT180D
/ steering wheel nut, MT180D
Update,if anyone cares.
The balls in the steering box, the recirculating balls, all came out which caused the loss of steering. The box was full of water and the lower bearing was frozen.
I ordered 5.5mm balls, bearing and shaft seal from McMasterCarr.
I cut off the threaded portion of the shaft that holds on the steering wheel and tig welded a 1/2-13 threaded portion of a bolt to hold the wheel.
All good now I mowed a 1/2 acre yesterday.
So far, so good.
Now to address the blowing batteries up problem.
/ steering wheel nut, MT180D #13
I know that I'm a bit late but just located my parts manual for MT180,180D and it shows nut item # 25 to be PN A503 0114 001 to be M14
Now you know!
/ steering wheel nut, MT180D #15
Looks about right, gets the job done. Thumbs up.
CATERPILLAR 304E2CR EXCAVATOR (A62129)
CATERPILLAR...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2015 Volkswagen Golf Hatchback (A60352)
2015 Volkswagen...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2020 DRAGON 150BBL ALUMINUM (A60736)
2020 DRAGON 150BBL...
