Traction Steering wheel alignment
/ Steering wheel alignment #1
AllByteNoBark
South Texas
Kubota L3560HSTC LE, John Deere 950
Recently got a spinner for my steering wheel as I have had one in the past and found it handy.
Put it on today and mowed a couple of hours with the RC. The surprising part to me is on this Kubota the steering wheel does not always return to the same spot. Is that normal?
I put the spinner on at about the 10:00 position withwheels straight.
Sometimes it would be there when going straight but more often than not it would end up at some random position. Never had that happen before on anything else.
Kind of makes the spinner a pain and will probably take it off.
/ Steering wheel alignment #2
It's due to being hydraulic steering. Much different than a direct mechanical (gear) linkage. I thought just as you when I first put a spinner on. You will get used to it being in a different spot.... I wouldn't be without one now!
/ Steering wheel alignment #3
Yes completely normal on a hydraulic steering system. I never have liked those spinners.
Kind of what I figured. Just had not even thought about it.
/ Steering wheel alignment #5
Yes, normal. I literally wore out a pair of gloves by palming the wheel in 2016 during an East Coast blizzard. I now use a spinner, mostly for snow plowing.
/ Steering wheel alignment #6
The steering on late model Kubota's is not hydraulic, it's hydrostatic and it's perfectly normal foe the steering wheel to land on different positions because there is no hard mechanical connection between the steering wheel and the front end. Why Kubota steering wheels aren't cast with a definite spoke (or emblem) pattern. I run 'suicide' knobs on mine, never pay any attention the the 'landing position', just use them for their intended purpose which is quick turning of the wheel and steering.
/ Steering wheel alignment #7
Hydrostatic steering has been on certain tractors since at least the early 70's. No the steering wheel will never be in the same place.
/ Steering wheel alignment #8
agreed, my 45 year tractor is like that
/ Steering wheel alignment #9
Don't think so much about your knob position and you will probably get use to it.
/ Steering wheel alignment #10
Mmm, this thread got me thinking,
Just a question, what happens on fully hydrostatic steering if the engine dies while descending a hill with turns?
Will the orbital valve still provide hydraulic pressure to the ram and therefore wheels If you turn the steering wheel ?
If not, that would seem to be a small (safety feature) of mechanical steering with hydraulic assistance versus Full hydrostatic steering.
/ Steering wheel alignment #11
It will still allow you to have a fully controllable steering. Although it will be very very hard to turn the steering wheel.
The orbitrol steering valve is equipped with check valves that allow the operator to steer even without the engine running.
/ Steering wheel alignment #12
Hmmmm....don't do that.:eek:
I tried turning the wheel without the tractor running and it will still move the tires so would guess you would have some steering but probably be interesting.
/ Steering wheel alignment #14
It would steer easier if the tractor was in motion..
/ Steering wheel alignment #15
Agreed. The more you use it the less you think about it. If you aren't sure if you like it take it off and see if you miss it. I know I would.....
/ Steering wheel alignment #16
One our Texas members installed 3 spinners on his Kubota so one was always handy!
/ Steering wheel alignment #17
Zebrafive
My I ask what 45 yr old tractor you're referring to? Surely not your 2030 that has mechanical linkage for steering?
Been a few weeks since I posted this but am going to leave the spinner on. It is just to handy to give up. I especially like it when running the RC and backing in around things. Getting used to the idea that it is not always in the same location and don't think about it at this point.
/ Steering wheel alignment #19
When my eyes and right hand are busy, the thumb on my left hand circles the steering wheel until it finds the spinner. It has been doing it that way for a looong time.
/ Steering wheel alignment #20
Will happen all the time if steering is on a hydraulic circuit.
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
Knapheide Service Bed (A61165)
Knapheide Service...
17394SFL (A61568)
17394SFL (A61568)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2008 KOMATSU PC200LC-8 HYDRAULIC EXCAVATOR (A64047)
2008 KOMATSU...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
