Steering valve leak
/ Steering valve leak #1
DHS
Watertown, SD
PT-422
The steering valve is leaking on my three year old 422. It appears to be leaking from the top of the valve just below the steering wheel. I assume it is a leaking seal. Has anyone had a similar problem? I will call PT in the morning.
DHS
Mossroad,
I spoke with Terry at PT. He thought it was the seal. I had the option of sending the valve to PT or shipping the seal to me. Seems the lower part of the valve must not come apart because of all the inner pieces. Terry said the valve is unusable if the lower section comes apart. A new valve is $500. So, I had them send the $74 seal to me. I should receive it early next week. I'll let you know how interest of a job it is. It is a slow leak and I am using the PT for spring cleanup.
/forums/images/graemlins/ooo.gif
DHS
Steering valve seal replacement:
I ordered the seal from PT and Terry provided the advise. It is an easy job if you don’t screw up. You don’t want to separate the lower sections of the valve. These are the steps I followed.
Label and remove the five hydraulic hoses from the bottom of the valve.
I covered the five fittings on the valve with 3/8" furniture tips to protect the fittings.
Removed the steering wheel with punch and hammer. Dis covered the steering wheel does not need to be removed to remove the steering valve.
Removed four nuts that attach the valve to the control panel and removed the valve.
Duck taped the lower 3/4 of the valve and placed it in a vice.
Removed the four bolts holding the valve together.
The top section and the seal/spacer come off easily.
Installed the new seal/spacer and center it.
Install and tighten the four bolts.
Install the valve, attach hoses, and connect the steering wheel if you removed it.
It was easy with Terry’s advice.
Dale
/ Steering valve leak #5
Great job DHS!
The perseverance and ingenuity of PTers on this Forum is amazing, if not somewhat daunting. I am certainly pleased to have this knowledge base at my fingertips.
/ Steering valve leak #6
Congratulations on the repair and thanks for the notes. Sounds like you are comfortable working on the machine. Dirt is the enemy of these hydraulics. Nice tip on the furniture tips for covers. /forums/images/graemlins/wink.gif
Thanks. Yes, I am comfortable working on my PT. I have mended a number of small problems. The furniture tips were to protect the easily damaged connectors. Keeping it clean was an added benifit.
Dale
2018 CASE TV380 SKID STEER (A65053)
2018 CASE TV380...
UNUSED PARBREAK GCC56 2 PRONG BALE SPEAR (A65055)
UNUSED PARBREAK...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2006 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2006 MACK CHN613...
2019 KUBOTA SVL75-2 SKID STEER (A65053)
2019 KUBOTA...
Jeep Metal Tailgate Metal Decorative Sign (A64557)
Jeep Metal...
