Steering Question
/ Steering Question #1
alexsbuddy
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
I have an XG3037, 160 hrs, and just noticed that the steering wheel can continue to rotate even when the front wheels have reached the limit of their turn. Is this normal? Thanks.
/ Steering Question #2
Yes, it's normal. You can also turn the wheel while the tractor is off, and it won't turn the wheels. It's because tractors like ours use hydrostatic power steering not a mechanical setup.
/ Steering Question
Thank you, motownbrowne. Had me worried since I hadn't noticed it before.
/ Steering Question #4
If you have any OCD, that steering wheel being off will drive you bonkers. :laughing: Other than that, it's perfectly normal.
/ Steering Question
Yep....Chief OCD'er....I probably should begin looking for an Errant Steering Wheel support group!
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2008 VOLVO  EC330CL (A65643)
2008 VOLVO...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
Used 20' Container (A62679)
Used 20' Container...
New/Unused Hercules ATV Sprayer (A65583)
New/Unused...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
