Steering Pump Fluid
/ Steering Pump Fluid #1
confederatemule
Can someone tell me what hydraulic fluid goes in the power steering pump on a 1977 Massey Ferguson 255 tractor? I have had no luck trying to google search.
Mule
/ Steering Pump Fluid #2
Any good hydraulic fluid will work fine.
Even UTTO!
Even UTTO!
Thanks CalG, for the fast response.
Aren't there different weights of hydraulic fluid?
Mule
/ Steering Pump Fluid #4
Should be the same fluid you put in the tranny.
All the Massey information I could find called for Massey-Ferguson Permatran III for the power steering pump. I called all over town, every place, I could think of, that was open on Saturday. No one had a listing in their books. I finally called Tractor Supply Company [TSC]. The feller said; "I don't have a listing, but let me go look on the bucket." He did and sure nuff Permatran III was listed on their brand of hydraulic fluid. The brand is "Traveler Premium Tractor Fluid" They sell it in 2 gal and 5 gal containers. I bought a 2 gal container for $19.47.
Thanks, again y'all fer helpin me out with this little prolem. The nearest Massey dealer to here is near 100.00 miles, and they are closed on Saturdy.
Mule
/ Steering Pump Fluid #7
Mule
Yep, that's what I use in my MF 241 power steering pump (also calls for Permatran III)....no problems with it so far (other than the steering cylinder seals are leaking now that it's cold!).
Well, GManBart, I do not know if my pump had factory or aftermarket fluid in it, but the steering seals leaking is why I finally needed fluid.
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
Year: 2018 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A59230)
Year: 2018 Make...
