Steering problems
   / Steering problems #1
greene acres guy
Southern Michigan
John Deere 2305
I recently purchased a 2305 John Deere with R4 tires. I love this tractor , however when you turn all the way to the right the tires rub against the pin that releases the front mower deck. Anyone else have this problem, if so how can I remedy the problem. Any help would be appreciated. Greene Acres Guy
   / Steering problems #2
Can you reverse(side for side) the tires and solve the problem?
   / Steering problems #3
Is there a turn stop for the steering? On the Case and NH tractors they have an adjustable bolt that stops the steering so it can be adjusted not to hit FEL brackets etc. You might have something similar.
   / Steering problems
Thanks for the tip,I will check and see if there is an adjustment for that. A friend of mine told me the larger JD ag tractors have an adjustment for it.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
30' 6-Ring Grain Bin (A50774)
30' 6-Ring Grain...
