steering problem with deutz tractor
/ steering problem with deutz tractor #1
Ranggamati
I have a borrowed 4x4 six cylinder tractor (about 100 HP). I have no idea what the model is or where to find the number. It has an intermittant steering problem. At times you can steer it with two fingers; other times it takes a 40 acre field to turn around. It will steer under powerjust not well when it decides to mess up. I'm trying to drag logs with it and find this problem aggravating and dangerous. The owner bought it used from Smith equipment in Wartrace Tn. They are no longer in business. Any help will be appreciated.
India Property Reviews
/ steering problem with deutz tractor #2
gday
there must be a power steering pump and or resovoir somewhere so check they are full and you have no drive belts slipping,you know just check the obvious stuff.
if it all appears ok it may be a relief valve in the system which would require experience to find or the steering box or cylinder whichever it has...
sometimes there are reliefs,that look like a small 10mm pin poking out of a small block with hoses attached that neutralise the pressure when on a full lock turn,they can stick at times causing poor or no steering.
so good luck
/ steering problem with deutz tractor #3
i'm not familiar with that unit.. but if it has a seperate PS sump.. check to see if it is real low on oil..
soundguy
2020 Forest River Surveyor Camper, VIN # 4X4TSVZ21LL037533 (A61165)
2020 Forest River...
2008 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A61568)
2008 Chevrolet...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
UNUSED WOLVERINE TCR-12-48H HYD TRENCHER (A62131)
UNUSED WOLVERINE...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
