Steering locks up
/ Steering locks up #1
chelydra
Ditch Witch
Thought that this had been covered someplace, but couldn't find the post...
Occasionally, the steering on my CK20HST locks up. Doesn't just get hard to steer - can't move at all. I'm not sure, but I think it may only be in 4WD. It always seems to happen when I'm in a very awkward position, deep in loose dirt, on a slope, etc. So far, it's always released with a little back-and-forth. But I've been in a few situations where that could have been dangerous - didn't want to move at all w/o changing wheel pointing.
Is this normal?
Thanks-
Chelydra
/ Steering locks up #2
My CK30HST will have issues with the hydraulic system if I am on too steep of a hill.
Does it feel like Hydraulic Cavitation? Or more like a mechanical lock up of sorts?
God Bless,
Wiley
CK30HST:72"BB, 60"Rotary cutter, 72"RFM, 1000lb bucket forks.
/ Steering locks up
Feels like total mechanical lock-up to me. What does cavitation feel like? I'd have guessed that that would make controls soft, not hard.
First few times, I thought I'd jammed a rock into the steering someplace - a stick wouldn't have been that solid. But it's nothing external, as far as I can tell. More like some combination of valving that block steering flow.
Anybody else ever experience this? If not, I guess I ought to tell the dealer again - still in third year of warranty.
-Chelydra
/ Steering locks up
I asked the dealer, who said that "it happens sometimes" - something to do with the valving. That's what it feels like: shut valve on the steering lines so the wheel is turning against a solid block. He said that there's nothing broken. I hope he's right...
When it happens, the only way out is to roll back and forth a bit with the HST. Problem is that it always seems to happen when I'm in a difficult place, either side-hill or a deep hole, and the direction in which the steering is locked is not the safest or most useful. Guess every machine has its quirks.
-Chelydra
/ Steering locks up #5
That sounds like my dealer;"they all start hard","oh, nothing to worry about","it will wear in" etc.,etc:rolleyes: I'm glad I don't have your problem with the model I chose
/ Steering locks up #6
No not yet on this '07 model, though I'm still low hours. It's been Ok so far on medium slopes steering amongst exposed tree roots and stumps.
/ Steering locks up #8
700+ hours on my wifes CK 25 hst with loader and backhoe... the only steering problems we have had is the loose nut behind the wheel.
/ Steering locks up #9
Virgil, I'm guessing Mrs. Virgil doesn't follow the forum or you might not be so free with the jokes!:D
/ Steering locks up #10
I thought he meant literally that a nut was loose.:p
/ Steering locks up #11
Seriously, there is nothing 'normal' about the steering on your tractor locking up!
Get the dealer to fix it. Do you really want a tractor that could have, what is in effect, a steering failiure at any point?
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
Freightliner Columbia (A63689)
Freightliner...
2018 Peterbilt 579 (A64127)
2018 Peterbilt 579...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
