Steering is out
/ Steering is out #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Tractor only turns to the left. Struggles to find the right. I just had the steering rebuilt by PT because it leaked. I have run it maybe 6 hours...
Any diagnosis suggestions before a call to PT tomorrow?
/ Steering is out #2
I am assuming that you reconnected the hoses up correctly, and did you bleed the cylinders. They might have some air in them. I believe your steering unit is like the rest , and if that is the case, after everything was connected, did you have the ability to lift and curl. I believe that the steering has priority over the lift and curl. If you did, that proves that the fluid is moving through the steering unit.
Is this the same machine that PT refurbished. Just seems that you have had a lot of trouble with it. I think I would find some good hydraulic techs in your area, and get to know them really well.
/ Steering is out
Hoses are good, curl and lift function are strong. Turns very good to the left, not so good to the right. Did not bleed the system. Did not know I had to (Terry did not mention it when I spoke with him). And because everything else is working, I don't think it could be air in that system...
My gut says it is the steering mechanism... Big bummer....
/ Steering is out #4
Unless this year is different, I think the factory is closed fourth of July week.
If there are no leaks in the steering hoses, I'd certainly drive it around a bit and turn lock to lock to make sure the air is purged. Does sound ominous, however. I don't know enough about the steering valve to know what might go wrong.
/ Steering is out #5
A hydraulic system that has air in it will try and work, but what you are doing is trying to compress air to equal hydraulic pressure. It may work to some degree, but will feel mushy, similar to air in your car brake system.
I would raise the machine off the ground, and attempt to bleed the lines and cylinders. Should be easy enough to do.
/ Steering is out #6
Just another thought, maybe one of the hoses is reversed, and you are pushing against the other cylinder. Unhook both cylinders, and turn the steering to the stop in both direction, and see if you have a logical situation , and confirm proper operation.
/ Steering is out
One thing I forgot to say is that it worked for for 6 hours and then failed.. Its the mechanism. I hear there is a distributor in Portland and will call tomorrow...
Boy will it mess me up if PT is closed tomorrow...
/ Steering is out #8
One of your cylinders isn't binding by any chance is it?
/ Steering is out #9
The Steering quit working on mine a few weekd back. The steering wheel would spin, but it would not turn.
To fix it, we had to rebuild the steering cyclinders. It can be doen with them mounted on the pt, , we did it on the job site. U just need someone to hold the cyclnder with a big pipe wrench and then unscrew th e cyclinder and replace the seals.
/ Steering is out #10
Hmmm.... I was beginning to sense deja-vu all over again, wherein I rebuilt my 1845's steering valve only to discover it wasn't the steering valve at all - just a busted seal in a steering cylinder. But on reflection I'm not so sure - in my case I had a loss of steering in both directions. You might get some jic plugs and try isolating first one cylinder and then the other and see if the problem is cylinder specific.
PT-1845 Repairing Loss of Steering Input
I'm beginning to feel a little steering slippage again... (darn)
Sedgewood
/ Steering is out
talked to Terry. He said it is one of the two cylinders performing the steering is out. He said to rebuild both. This makes me happy that it is not my steering control.
Terry is overnighting the parts so I can have the rest of my week...
Anyone have a picture essay on how to do this? He said it is easy, but I am a so novice at this hydraulics stuff....
/ Steering is out #12
we did it on a customers site, didn't even bring the pt home.
With two people u can leave the cylinders on the pt, just unbolt the shiny end (this is the part which unscrews out of the cylinder housing).
One needs to hold the housing with a pipe wrench while the other unscrews the cylinder nut. Then it slides out, install the new plunger and seals, put it all together, and there u go.
We didn't need to bleed it out or anything.
Without two people, you'll probably need to pull the cylinders off and put them in a vice as you rebuild them.
Should take about 10 minutes per cylinder.
/ Steering is out #13
Ok...where are the pics! Gotta have pics. ;~)
/ Steering is out
Saddly I left my camera on the tractor when I ran into town. Could have kicked my self cause I was so insistant on making sure you guys had photos of the process...
/ Steering is out #15
Sedgewood,
Many thanks for your information on the Steering Valve. I had mine apart to eliminate excessive looseness, by removing the plastic partial shaft bushing, and installing a full length Oilite Bushing, much better now While making this correction I noticed there was no means of Identification again. Again thank you for the Hydraguide info, it is always good to have some means of I D.
Bill
Set 4 - 10-16.5 tires on wheels for bobcat (A61572)
Set 4 - 10-16.5...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
