Steering Cylinder Rod Guide Replacement on JD 3203; Difficult?
   / Steering Cylinder Rod Guide Replacement on JD 3203; Difficult? #1
Emperor
Baton Rouge
John Deere 3203
I have a JD 3203 Compact and was wondering why my steering was drifting after cutting grass. Noticed hydraulic fluid was spewing from the Power Steering Cylinder "Rod Guide" seal. Looks like a stick or something may have stabbed/got jammed between rod and rod guide and damaged the seal.
Noticed that the Rod Guide on my model, matches several other models. Also noticed the part alone is very expensive (almost $300). As ridiculous as that is, the tractor is useless while that is broken.
1. This looks like a fairly simple task. Is it?
2. If so, what is the basic procedure for disassembly and replacement of that part?
3. Should I consider an issue with the piston as well? It's expensive too!
Thanks!
   / Steering Cylinder Rod Guide Replacement on JD 3203; Difficult? #2
You need the seal kit, not the rod guide
Kit -LVA14168
Thanks Joe.
I suppose I will remove the existing seal and see the extent of the damage. Where did you get that part number and / or see a diagram that offered a "kit" that I assume will be far less expensive, instead of the $300 parts?
   / Steering Cylinder Rod Guide Replacement on JD 3203; Difficult? #4
last item on the list on the cylinder page
Thanks again!
John Deere 3203
Replacing Seals
Piston on rod is on there pretty snugly. I am trying to remove it.
Can someone tell me if the piston is removed from the rod by unscrewing it, or does it need to be pulled or tapped free?
Also, if it is removed by unscrewing, how do put enough force on it in the vise grips to avoid damaging the piston?
Thanks.
   / Steering Cylinder Rod Guide Replacement on JD 3203; Difficult? #7
Maybe Loctited on? If so, you'll need heat to loosen the Loctite. As for holding the rod, can you double nut the other end?...............Mike
   / Steering Cylinder Rod Guide Replacement on JD 3203; Difficult? #8
Need either copper, aluminum, or UHMW v-block covers for your vice jaws to clamp the rod without marring it. It looks like the piston is 2 pieces jam nutted together on the end of the rod. May need to make a couple clamp wrenches from aluminum bar stock. Think barrel wrench if you are familiar with gunsmithing. s-l500.jpeg
Need either copper, aluminum, or UHMW v-block covers for your vice jaws to clamp the rod without marring it. It looks like the piston is 2 pieces jam nutted together on the end of the rod. May need to make a couple clamp wrenches from aluminum bar stock. Think barrel wrench if you are familiar with gunsmithing. View attachment 569561
Piston was just sitting on the tapered end of rod. Got snug from the pressure. I used a bearing pull to break it free. Worked perfectly.
   / Steering Cylinder Rod Guide Replacement on JD 3203; Difficult? #10
Glad you got it free.
TEST BID LOT (A50774)
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
7046 (A50322)
7046 (A50322)
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
