Steering 7520
/ Steering 7520 #1
NorthZulchTX
Mahindra/7520
Mahindra 7520 has steering problems.
Steering does not respond when steering wheel turned.
Takes several turns of steering wheel to make wheels respond.
Fluid level in reservoir full.
/ Steering 7520 #2
Is the tractor new to you. Has it been sitting a long time. Is it cold where you are???
/ Steering 7520 #3
When you say the reservoir is full, do you mean the power steering reservoir under the hood?
Could be the steering cylinder is bypassing internally.
The 6520 and 7520 have the power steering pump connected directly behind the hyd. pump. Might be a coupling there, that is inop. Are the PTO and loader working as normal?
hugs, Brandi
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
Unused 2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
Unused 2024 HLA...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
2020 18ft Arising Industries T/A Enclosed Cargo Trailer (A66738)
2020 18ft Arising...
