steep property,what to use
/ steep property,what to use #1
arkydog
Arkansas
kubota 3200hst loader and bh77 backhoe, allis chalmers 816 backhoe
My best friend is building an house on 5 acres in the woods of the ozark hills. Around the house the grade is 19 degree and goes down to 28 degree at the back of the property. I had heard not to use a tractor over 15 degrees slope, so what are his options to buy for mowing around the house and also cleaning up at the back of the property. My thought would be some kind of track vehicle, so any suggestions would be greatly appreciated.
thanks
arkydog
/ steep property,what to use #3
Check out the Power Trac line of articulated hydraulic tractors at www.power-trac.com
While all of their models can handle steeper slopes than standard CUTs, they have two models Rated for 40 and 45 Degree slopes!
I live on a very steeply sloping property in Colorado and needed to do extensive wildfire mitigation involving removing many trees and slash on 30 degree plus hill sides. I have the single wheel version of the PT-1845 which has worked quite well for this application.
The PowerTrac line has a wide range of mower heads as well as many, many other attachments making these units equal or better than CUTs in terms of versitility.
There are several other machines such as Steiner and Ventrac that are excellent slope mowers, but quite limited in terms of other capabilities. The PTs are very good as slope mowers, but also very good at many other tasks.
See the Power Trac forum on this site for owner information in addition to the company web site listed above.
Good luck
/ steep property,what to use #4
I used a BX23 on a 25 degree right to left with a 20 degree up slope. Have cut and leveled that bit of track now.
Scarey but the BX seemed stable even though I wasn't.
/ steep property,what to use #5
gaspasser,
Welcome to TBN! That is amazing video of the hillside tractor you found.
Don't forget to filll out your bio. Let us know a little more about you.
OkieG
/ steep property,what to use #6
gaspasser, that's a pretty wild looking unit you found. I wonder how the deck can float and adjust, but still provide the stability? I've never seen anything like this. Neat.
/ steep property,what to use #7
Arkydog--
I wrestle with the search for the perfect hillside mowing setup all the time, as I have hills right by the house which are 20 and 33 deg. Right now I use a hydro CUT, backing up and driving down the steep hill and driving up and down the less-steep. The Power Tracs have a great and loyal following but you have be ready to do your own repairs because they have no dealers; the PT board on this site gives great information about the ups and downs of that situation. As to dedicated and reasonably-priced mowers, the current slope leader, I think, is the Hustler ATZ, a zero-turn rider with slope-holding modifications. There are many pull-behind-ATV mowers. Going to something with tracks sounds like tons of fun--watch the movie at Litefoot's website, where an ATV climbs a 22" vertical obstacle--but adds a bunch of cost.
Another possibility with the kind of slopes you're talking about is to turn them into prairie/meadow, mowed occasionally or not at all.
Since he is my best friend and knows almost nothing about equipment and I know only slightly more, would an ATV work on those type hills, one that his wife could use to pull a small utility wagon up and down and across those hills, or are we still talking about some of the same equipment mentioned above. Would something like a gator work, or are we back to the same roll over problem?
Thanks
arkydog
/ steep property,what to use #9
A two wheeled tractor would handle the job easily even running across the slope. There's a recent thread that covers the topic. If he wants to ride, I'd look for a Unimog setup for Ag or construction work.
/ steep property,what to use #10
<font color="blue">I wonder how the deck can float and adjust, but still provide the stability? </font>
Freds,
I was thinking about that, too. I bet the mower deck pivots, kinda like the front axle on a conventional CUT, and possibly provides little stability to the unit. Maybe like riding a bicycle across the slope. That doesn't sound very stable though, does it?
OkieG
/ steep property,what to use #11
Grettings from the ozarks.
I have the same problem.
The ozarks are not very tall, but man they can be steep in places.
Is the slope compound? If not you can just drive up and down it. This works pretty well since a tractor is safe up and down 20 degrees.
But if its compound, slopes in two directions, it's hard to maintain that up and down angle, partciluarly if you need to turn around at one end.
In some cases you can back up and then drive down, repeat process.
If you do this get a 4wd and get a loader. The 4wd will save you. One day when I was on a steep hill that I was cutting, the rear tires started spinning. Thought I was stuck for sure and worried I would start slipping further down. Looked down and realized the front wheels where not spinning /forums/images/graemlins/blush.gif. I forget it was not in 4wd. Dropped it in 4wd and hit the diff. lock and she backed right out no problem.
The loader is your emergency brake. Sounds funny and certainly not what you want to do on a regular basis, but it has saved me on occasion.
Leave the bucket it on and if you get in trouble just drop it. Acts like an anchor. Also useful for finding rocks, ahead of the mower.
If you choose to let it grow wild, keep in mind that the natural state is probably an oak/hickory forrest and it will go back to that in time. The problem is in the short run you will end up with 10 foot briars and persimmon trees.
four legged mowers are another option, but cows only eat the good stuff and if you have briars they will avoid those areas and the briars will spread.
Goats are better, but the fences are alot more trouble.
The 45 degree slope mower is probably the ideal solution plus may be some four legged helpers, until you see the price on that mower! /forums/images/graemlins/shocked.gif
Cost as much as a ultility tractor and its not setup to run a bailer or do the common tasks a farmer needs.
Fred
/ steep property,what to use #12
Without a doubt check-out Power-Trac. I had one for 7 years mowing hills with slopes up about 25 degrees, never worried about it tippin' over.
My main worry is when I'd get into wet and slippery conditions and my mowers might slide a little, best not to mow on slopes after rain or a heavy dew.
Yes you do have to maintain it yourself. However I found that they always had the parts I needed and shipped them quickly. I also found that it is fairly simple to maintain.
Have fun and good luck pickin' something out.
Eric P.
/ steep property,what to use #13
To OkieG & the forum - just started browsing about 3 weeks ago. My JD 4710 was overheating and I tried to find a solution. Couldn't find one so cable-tied the radiator hose to the air intake hose to get it away from the muffler. Grew up on a farm near Lawton, OK raising cattle but baling hay in the summer on Ft. Sill. Have 20 acres in Logan Co. that keeps me busy. Active in Boy Scouts, though my sons are grown and out of the troop. My wife and I know that there are still kids that need help and an adult role model. I am an anesthesiologist (gaspasser) and practice in OKC.
I was actually browsing the internet trying to find a source for an H&H toothbar when I went to the Deweze site - we used to have a Deweze bale wagon - and saw the mower. I finally broke down and emailed Henro and he was very informative on where to find H&H Sales.
Due to my schedule, I won't be on every day but will try to check the discussions every 2-3 days.
Thanks for all the info.
/ steep property,what to use #14
OK - I posted this in Lawn & Garden and have gotten no responses.
Anyone have any experience with a Swisher Postmaster trimmer? It pulls behind an ATV or riding lawnmower and is a self-contained string trimmer.
I found one negative rating on the internet somewhere. It looks neat - like it would do the job to trim the fence rows.
Northern Tool Swisher Postmaster
/ steep property,what to use #15
Arkydog,
I've seen a variety of industrial as well as "homemade" solutions for vehicles on slopes.
Here are some, if you can picture what I'm describing.
1. Set rear wheels extra wide
2. Similar to #1, but use an extra wheel hub between axle and wheel (2 hubs on one side, one or both with tires). Sort of like "duallies" on one side.
3. Extended axle on one side. This one is tricky due to balancing and reinforcement. The one I saw used an axle from a larger tractor (longer) on one side. Not sure how it was connected.
4. Using "outrigger" with a wheel on the end. This could be hydraulic to adjust for position. Bracing would be important.
If you must mow across a slope, it is easier to always mow from one side (leaning either left or right) and modifying only one side.
What else do you (in a perfect world) want to do with the tractor? Most of the above would still allow you to do other things with the tractor.
The specialized unit you posted a link to is very interesting, but seems more for a single purpose, like a commercial situation. It also looks like it may slide on an uneven surface, something to watch out for.
Pretty cool, but chances are good that once you get a tractor, you'll find all kinds of new uses for it.
Again, it depends upon how you want to use it and which option you are most comfortable with. Since you are new to tractors, you may not feel comfortable making your own modifications.
If not, don't do it. Most important thing here, is don't get hurt. A roll can and does kill, so be sure.
Good luck, and let us know how you decide to go.
-JC
PS- Welcome to TBN!
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
