Steel SIP construction
   / Steel SIP construction #1
cmkavala
steel SIPs are great for insulated buildings this 3600 sq. ft. garage/apartment was completed in just 6 days
   / Steel SIP construction #2
Chris,
Agreed. SIP's are a great way to get a building up fast and insulated at the same time. And the walls are always straight!
   / Steel SIP construction #3
My house is a timber frame with OSB/ sheetrock SIP panels. Two of us did the whole house in less than a week including the roof. I swear I can heat my house with a couple of candles.
   / Steel SIP construction #4
Interesting project. Where is this located?
I have yet to see any steel SIPs, but it sure looks like they have gotten
the weight down enough that they are much easier to lift vs. OSB SIPs.
Is the interior finish left as-is, or is there something you put over the steel?
   / Steel SIP construction #5
Like the last replier, I am curious about where your building is located? Seems like a great idea for an industrial type of building, a shop, or whatever, but I wonder about thermal transfer thru the metal edges, etc. in a cold climate? SIPs are very interesting in cold climates where energy usage hurts, for sure!
Varmit;
Great question, steel SIPs were originally used for the cold storage industry, but additional testing in recent years have proved them to be viable for other uses including homes , commercial and light industrial.
Thermally broken channels are used in cold climates, same as a cold storage building in Miami might be 90 outside and -15 inside or a heated commercial building in Wisconsin might be -15 outside and 70 inside.
The panel core is solid foam with no studs or splines to transfer thermally, all other channels are handled by thermal breaks
Dfkrug;
that project was done on Brunswick, Ga. in a 130 mph hurricane wind zone, interior is left "as is" . Steel SIPs used as homes are coverd with drywall on the inside.
Steel SIPs are 1/2 the weight of OSB sips and about less than 2# per sq. foot.
2 men can easily handle a 16 ft/ panel
No cranes are ever used, roof is set with the assistance of 2 scissor lifts
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55218)
PENDING SELLER...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
Informational Lot - Financing (A55218)
Informational Lot...
