Steel or plastic roof?
   / Steel or plastic roof? #1
Notforhire
Southwestern Virginia
Kubota L47TLB
I intend on getting a glass windshield and roof for my RTV900.
Kubota makes both steel and plastic roofs.
Any opinions on which is better and why? Noise, durability?
It needs to be compatible with a soft enclosure/doors, etc. that I may add later.
This vehicle is used primarily for work.
Thanks.
   / Steel or plastic roof? #2
Plastic (HDPE or ABS) is all we've ever used and never had a problem with it. For a roof, I'd say its a superior product. Seems that plastic are better at absorbing sound than steel is. You can glue some of that sound barrier closed cell foam to whatever you get.
   / Steel or plastic roof? #3
Pros and cons to both I'd guess.
Weight vs. strength, noise, fix-ability (dents vs. chips/cracks), UV (sun) resistance vs. rust resistance, etc...
Sun makes plastic brittle over time. Is it stored out of the sun?
   / Steel or plastic roof? #4
I have a plastic vaccume formed roof on my MULE. It's not very straight and true, but then doesn't dent either.
   / Steel or plastic roof? #5
I have no idea what kind of plastic Kubota uses on their tops.
I do store the machine indoors.
I'm leaning towards metal mostly because I could repair/repaint it if necessary.
   / Steel or plastic roof? #7
Thanks.
The one you didn't mention is the diamond plate aluminum top sold as aftermarket canopy. Looks very durable and much easier to fix dents plus lightweight compared to steel and also gives you the ability to mount lights or other things to it without breaking it.
   / Steel or plastic roof? #8
My Polaris UTV has a molded plastic roof. It fits well, is secure, no noise, no dents.
   / Steel or plastic roof? #9
Here are 5 lights mounted on a plastic roof. 6 years later and many, many branches pushed away with the guards, they are still there and never been repaired. How can we improve on this design??.
   / Steel or plastic roof? #10
Looks like a great design Arly, no complaints. Being here in Fl the rate at which plastic detiorates pretty fast and becomes brittle, I am sure there are probably excellent plastics out there but I liked the looks of the aluminum. I would thought the temps there would have made plastic brittle
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
Kawasaki NR (A50324)
2015 Ram 4500 Utility Truck, VIN # 3C7WRKAJ9FG707673 (A51572)
2015 Ram 4500...
