Steel loop/hoop for a tow chain; where can I get one?
   / Steel loop/hoop for a tow chain; where can I get one? #21
Short Game said:
At the risk of repeating myself: Is there something wrong with just taking it around a trailer ball and hooking back to the chain with the grab hook?
I was told not to because the ball can shear off and become a projectile.
Thanks dad.
E/S
   / Steel loop/hoop for a tow chain; where can I get one? #22
How about cutting a circle and a slot on a 3/8'' plate. Drop the chain thru the circle and slide the chain into the slot. The circle then is placed over the ball. A small "V" could be added to the circle to slide up against the shank when pull was applied on chain.
   / Steel loop/hoop for a tow chain; where can I get one? #23
   / Steel loop/hoop for a tow chain; where can I get one? #24
Good information... thanks
   / Steel loop/hoop for a tow chain; where can I get one? #25
I measured the I.D. of the Bailey's grab loop (see post #3). It's 2.5". What I like is that you can slip a chain through the loop and grab it anywhere on the length of the chain. It gives me more flexibility than having the loop on one end only.
SimS
   / Steel loop/hoop for a tow chain; where can I get one? #26
ATV Hitches
Fifth item from the bottom
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A50854)
2007 PETERBILT 335...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
