Steel loop/hoop for a tow chain; where can I get one?
   / Steel loop/hoop for a tow chain; where can I get one? #21
Short Game said:
At the risk of repeating myself: Is there something wrong with just taking it around a trailer ball and hooking back to the chain with the grab hook?
I was told not to because the ball can shear off and become a projectile.
Thanks dad.
E/S
   / Steel loop/hoop for a tow chain; where can I get one? #22
How about cutting a circle and a slot on a 3/8'' plate. Drop the chain thru the circle and slide the chain into the slot. The circle then is placed over the ball. A small "V" could be added to the circle to slide up against the shank when pull was applied on chain.
   / Steel loop/hoop for a tow chain; where can I get one? #23
   / Steel loop/hoop for a tow chain; where can I get one? #24
Good information... thanks
   / Steel loop/hoop for a tow chain; where can I get one? #25
I measured the I.D. of the Bailey's grab loop (see post #3). It's 2.5". What I like is that you can slip a chain through the loop and grab it anywhere on the length of the chain. It gives me more flexibility than having the loop on one end only.
SimS
   / Steel loop/hoop for a tow chain; where can I get one? #26
ATV Hitches
Fifth item from the bottom
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
196046 (A50459)
196046 (A50459)
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
