Steel Cutting with Worm Drive Saws
   / Steel Cutting with Worm Drive Saws #1
authority
Alberta
Toro 328D, LS R4041H, New Holland Boomer 55, Case TV450B, Deere Z545R
I had a new Ridgid R3210 and decided to try a Freud Diablo D0648F 6-1/2" x 48-Tooth Steel Demon TCG Ferrous Cutting Circular Saw Blade 5/8" Arbor.
Reasoning behind the 6.5" was the tooth speed would be slower than a 7.25" blade, and I didn't need any of the extra capacity.
You can't even tell it's cutting anything on the light gauge (1/8") 3x4 tubing I tested it on, the chips are small and the cut is cold.
Other note is that this is a painted tube, and if you were completing a repair, there is not any heating or discoloration of the finish.
   / Steel Cutting with Worm Drive Saws #2
View attachment 362183View attachment 362184
pretty neat. I'm wondering what the cut would be like on a thicker piece such as 3/8"?
   / Steel Cutting with Worm Drive Saws #3
According to the printing on the blades, they don't recommend thicker than 1/8" or bigger diameters (tubing) than 1" -
I'd be interested to know what kind of blade life you're seeing, if you've used it very much... Steve
   / Steel Cutting with Worm Drive Saws #4
These blades work pretty good, I've gotten good results using a cheap skil saw.
But they do tend to rain down hot chips as they cut that then get everywhere. I picked up a Milwaukee metal cutting circular saw to build a maple syrup evaporator for my brother. It still makes a mess with the chips but is somewhat more covered in the blade area in that I didn't get the chips sprayed all over me anymore. For 300 bucks or so it was a pretty good buy, with a guide bar the fit-up on the 2x7x3 evaporator was practically perfect, very easy to tig everything together.
   / Steel Cutting with Worm Drive Saws #5
I've used various steel cutting blades in wormdrive saws and had lots of hot chips everywhere. For a while now I have used the Makita saw below which generates chips that are almost cold, and most of them stay in the guard. It cuts 1/2" mild steel with no issues. The battery lasts long enough that it is not a constraint, when it does run low just switch in the second battery. A speed square clamped to the work will give a perfect cut every time.
   / Steel Cutting with Worm Drive Saws #6
OK I have to ask that blade in the picture looks like it is mounted backwards. Does that saw run clockwise ?
   / Steel Cutting with Worm Drive Saws #7
Zoom in. You can then see that the teeth are opposite of where they look like they would be in the smaller picture, and the rotation/blade are all normal :)
   / Steel Cutting with Worm Drive Saws #8
Here is a closeup of blade. lots of negative hook and a controlled feed design. rotation is normal.
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
