Steel Cutting with Worm Drive Saws
   / Steel Cutting with Worm Drive Saws #1
authority
Alberta
Toro 328D, LS R4041H, New Holland Boomer 55, Case TV450B, Deere Z545R
I had a new Ridgid R3210 and decided to try a Freud Diablo D0648F 6-1/2" x 48-Tooth Steel Demon TCG Ferrous Cutting Circular Saw Blade 5/8" Arbor.
Reasoning behind the 6.5" was the tooth speed would be slower than a 7.25" blade, and I didn't need any of the extra capacity.
You can't even tell it's cutting anything on the light gauge (1/8") 3x4 tubing I tested it on, the chips are small and the cut is cold.
Other note is that this is a painted tube, and if you were completing a repair, there is not any heating or discoloration of the finish.
   / Steel Cutting with Worm Drive Saws #2
View attachment 362183View attachment 362184
pretty neat. I'm wondering what the cut would be like on a thicker piece such as 3/8"?
   / Steel Cutting with Worm Drive Saws #3
According to the printing on the blades, they don't recommend thicker than 1/8" or bigger diameters (tubing) than 1" -
I'd be interested to know what kind of blade life you're seeing, if you've used it very much... Steve
   / Steel Cutting with Worm Drive Saws #4
These blades work pretty good, I've gotten good results using a cheap skil saw.
But they do tend to rain down hot chips as they cut that then get everywhere. I picked up a Milwaukee metal cutting circular saw to build a maple syrup evaporator for my brother. It still makes a mess with the chips but is somewhat more covered in the blade area in that I didn't get the chips sprayed all over me anymore. For 300 bucks or so it was a pretty good buy, with a guide bar the fit-up on the 2x7x3 evaporator was practically perfect, very easy to tig everything together.
   / Steel Cutting with Worm Drive Saws #5
I've used various steel cutting blades in wormdrive saws and had lots of hot chips everywhere. For a while now I have used the Makita saw below which generates chips that are almost cold, and most of them stay in the guard. It cuts 1/2" mild steel with no issues. The battery lasts long enough that it is not a constraint, when it does run low just switch in the second battery. A speed square clamped to the work will give a perfect cut every time.
   / Steel Cutting with Worm Drive Saws #6
OK I have to ask that blade in the picture looks like it is mounted backwards. Does that saw run clockwise ?
   / Steel Cutting with Worm Drive Saws #7
Zoom in. You can then see that the teeth are opposite of where they look like they would be in the smaller picture, and the rotation/blade are all normal :)
   / Steel Cutting with Worm Drive Saws #8
Here is a closeup of blade. lots of negative hook and a controlled feed design. rotation is normal.
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2016 (INOPERABLE) FREIGHTLINER SD122 (A52472)
2016 (INOPERABLE)...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
TMA (A49461)
TMA (A49461)
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2015 TRANSMASTER LOWBOY TRAILER (A52576)
2015 TRANSMASTER...
