Steamy Cab
/ Steamy Cab #1
dnw64
SE Vermont, South Jersey
Kubota B3030 Cab
So far I've only used my B3030 Cab twice in the winter. Both times the inside of all the windows steamed up really bad. I ended up opening the two small side/rear windows and that helped a bit. It was almost like it was on "Recirc" - is there such a thing, and how do I turn it off?
/ Steamy Cab #2
I run with the AC on to get dehumidified hot air.
I assume your B3030 has AC?
/ Steamy Cab
Yes, it does have AC. Didn't think about that - it's been automatic on all my cars for the last 20 years or so... :D
Will give that a try. Thanks!
/ Steamy Cab #5
Yep, I have to run the AC with the heater also.
I start out with heat only till the tractor is warmed up and an pushing good heat the add the AC to dehumidify.
We are putting out to much humidity with our breath, I was going to say hot air but then we wouldn't need the heaters :thumbsup::drink:
/ Steamy Cab
Yeah, no "hot air" being generated here. Well, unless you ask my wife!
/ Steamy Cab #7
Don't forget you have the inside/outside selector lever on the ceiling of the cab,in the rear where it brings fresh air in through the cab filter,or recirculates the inside air.
AC is the key though.
Good Luck!
/ Steamy Cab
Don't forget you have the inside/outside selector lever on the ceiling of the cab, in the rear where it brings fresh air in through the cab filter, or recirculates the inside air.
That's what I was looking for, but agree that the AC will likely be the biggest effect.
Thanks!
