STEAM ENGINE QUESTIONS.
/ STEAM ENGINE QUESTIONS. #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
Steam engines will run in either direction. How are they started to go forward or reverse.
How is water added to the boiler. More presser is needed to get the water in.
Maybe someone on TBN will know.
There were steam tractors, must have needed to back up some times.
/ STEAM ENGINE QUESTIONS. #2
I have seen small engines where someone started the flywheel in the direction they wanted it to turn.
On old trains they used reversing the steam flow in the pistons to make it go backwards.
/ STEAM ENGINE QUESTIONS. #4
I don't think they reversed the flow of steam. They operated a reversing gear. The steam still travels the same direction, but the reversing gear moves an eccentric to make the wheels go in the opposite direction....
Reversing gear - Wikipedia
/ STEAM ENGINE QUESTIONS. #5
I always wondered about that too.
I guess for the water, they just use a small displacement pump.
/ STEAM ENGINE QUESTIONS. #6
/ STEAM ENGINE QUESTIONS. #7
Here's a really old movie with no sound, that explains it really well! It shows the reversing gear. The steam always travels in the same direction. They don't reverse the flow of the steam to make it go in reverse....
/ STEAM ENGINE QUESTIONS. #8
/ STEAM ENGINE QUESTIONS. #9
It gives the appearance that the steam is flowing in the opposite direction, but it isn't. It's still going back and forth as before. It's where the linkage pushes on the eccentric that determines the initial start of which direction the wheels are gonna turn, not the direction of steam flow. The steam just goes back and forth back and forth regardless of which direction the train is moving.
/ STEAM ENGINE QUESTIONS. #10
As for how they add water.... they use the pressure of the boiler to push water into the boiler. Sounds impossible, doesn't it? How can one force overcome itself?
/ STEAM ENGINE QUESTIONS. #11
I always wondered if one side of a locomotive was 180 degrees opposed to the other side or the same?
/ STEAM ENGINE QUESTIONS. #12
Here's a really good explanation.... the water isn't being pushed in by pressure, it's being rammed in by speed.
/ STEAM ENGINE QUESTIONS. #14
Thanks for the education.
/ STEAM ENGINE QUESTIONS. #15
Thanks. It does look like they are 180 degrees apart.
The technology and mass of those machines just blows my mind. I always thought how unfriendly those cabs were as if not designed for humans to spend time in.
/ STEAM ENGINE QUESTIONS. #16
Think how it must have been down in the engine compartments of big coal fired steamships...(especially in heavy seas)...there are some wicked stories about steam leaks...!
/ STEAM ENGINE QUESTIONS. #17
Each side has power on each stroke, forward and back, so one piston is effectively its own 180 degree opposite. So they set the other side's piston at 90 degrees. When setting up the crank, you will hear them talk about "quartering". So two pistons gives 4 strokes per rotation, which is also why they know which direction it is going to turn at any given moment based on the valve timing. At least one piston is in its power stroke and not TDC/BDC at any given time.
/ STEAM ENGINE QUESTIONS. #18
My employer sent me to steam school (one day seminar) at a steam controls company. Man, that was an eye opener.... especially the video of a guy in a manhole when a steam pipe burst. 1600:1 expansion ratio when it's let loose! Guy got popped out of the manhole like a cork. He survived and walked away!
Here's the video. You can hear the steam hammer going on and the guys talking about how you couldn't pay them enough to be in that vault. Some guy says to the guy in the hole "Maybe you should set out for a minute." Guy comes half way out and BOOM! WARNING: Strong Language (no $%@#!!!).
/ STEAM ENGINE QUESTIONS. #19
For the OP.
Feed pump
Slide valve.
[video]https://www.google.ca/search?q=slide+valve+steam&client=safari&hl=en-ca&prmd=inv&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjYve3ateraAhXMMd8KHfYkBMEQ_AUIESgB&biw=1024&bih=681#imgrc=UcFP_f512RI4WM:[/video]
/ STEAM ENGINE QUESTIONS. #20
What blew up? I saw flames.
I put the lance from my Steam Jenny down and it twisted, catching me in the shoulder, wearing only a T-shirt. I have not used it since and REALLY don't like STEAM anymore!
1995 John Deere 7400 (A60462)
1995 John Deere...
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2017 CATERPILLAR 816K LANDFILL COMPACTOR (A59823)
2017 CATERPILLAR...
2017 Ford F-250 Crew Cab Pickup Truck (A61568)
2017 Ford F-250...
Komatsu Excavator (A60352)
Komatsu Excavator...
