Steam Boiler or Steam Generator for Weed Control
   / Steam Boiler or Steam Generator for Weed Control #1
r8f1k
Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
Anyone ever use steam to kill/prevent weeds? Any ideas of how to make or use a boiler to generate enough steam to go up and down rows of apple trees to kill weeds and grass? I was thinking of using something like a household steam boiler, fueling it with propane, pulling it or pushing it with my tractor. I have front and rear PTO's on my Mahindra, so I could use a pump on the front or back to push the steam out onto the rows. Ideas?
   / Steam Boiler or Steam Generator for Weed Control #2
I tried killing weeds and grass around my inground pool one year using one of those large propane torches that you attach to a 25lb propane canister.
It burned the tops just fine, but not the roots, so everything ultimately grew back.
I’d think you’d have the same results with steam - unless you can kill the roots, it probably won’t be successful in the end.
   / Steam Boiler or Steam Generator for Weed Control #3
Water takes a surprising amount of energy to convert from liquid to steam. When this steam then condenses it then gives up this energy. So your idea may work to heat the ground enough to kill the roots. I like it. Direct the steam at the ground, not the vegetation. Keep in mind that this same steam will also condense on your flesh and cause terrible and deep burns. If you decide to use steam make sure your steam generator cannot build up enough pressure to burst. You do not want to experience steam burns. Also, because it takes so much energy to make steam you may discover you are using more fuel than you expect.
Eric
I know that steam takes quite a bit to get going.....I was also thinking about using a heated power washer tank. Would something like that be hot enough? I also heard that using steam makes seeds burst like popcorn.
   / Steam Boiler or Steam Generator for Weed Control #5
Maybe flame directly?
And from above:
Bruce
   / Steam Boiler or Steam Generator for Weed Control #6
A diesel fired Steam Jenny would probably have enough recovery capacity to maintain a consistent flow.
Let's just say I want to reconsider and use a flamer. I have access to a large amount of waste oil......not sure how to build that, but I assume pressurized with air and vaporized to create a flame.
   / Steam Boiler or Steam Generator for Weed Control #8
There are online many web sites that have directions on how to build waste oil burners. I remember looking at several many years ago. YouTube has a bunch of DIY designs. I looked specifically for a weed burner and here is a link for one that comes pretty close:
Good Luck,
Eric
Anyone know if there are ramifications when using flame weeding around young (3-6 year old apple trees)? I assume going too slow around any small tree is going to be a potential issue, but other than that.....?
   / Steam Boiler or Steam Generator for Weed Control #10
I looked into flame weeding many many years ago specifically for corn fields and weeding in the row between the corn plants. The factors seem to boil down to 1) speed of travel, meaning how long the plant is exposed to the flame 2) the age of the plant, younger plants are more affected by the flame than older plants which affects the travel rate 3) Age of the corn plant vs. the weed. The corn has to be old enough and the weed young enough that the weed is fried and the corn plant survives.
   / Steam Boiler or Steam Generator for Weed Control #11
Steam boilers dont deliver enough wet steam to effectively destroy soft leaved and stemmed vegetation quick enough. The answer is a heat exchanger that delivers saturated steam and boiling water at a volume enough to give forward movement and a delivery temperature of 212F. www.Weedtechnics.com manufacture such a product. They have US made heat exchangers and Australian design applicator heads for orchards and other intensive horticultural production.
   / Steam Boiler or Steam Generator for Weed Control #12
Don’t allow flames or heat to blister or burn the bark on the tree stem.
   / Steam Boiler or Steam Generator for Weed Control #13
Here you go. They were still doing this for tobacco beds locally when I was a kid:
   / Steam Boiler or Steam Generator for Weed Control #14
Before adding a few inches of good topsoil and seeding grass, I killed the weeds using a tiger torch. I quickly learned that you needed to wear safety glasses as tiny rocks would explode with the heat and it was not a quick process. An area about 15'x15' took me well over an hour. It did work well as none of the large course weeds came through the new grass. I haven't tried steam on my gravel drive due to the cost of decent equipment.
   / Steam Boiler or Steam Generator for Weed Control #15
Spend your good money on a hydraulic driven weeder with whisker switch/limit switch control and you can weed and protect all your fruit trees no matter how old that are.
   / Steam Boiler or Steam Generator for Weed Control #16
We use both a mechanical weeder and multi clean brush made by Clemens. Great products and work surprisingly well (and fast). I am also looking at steam options and have the setup…just not enough time to fiddle with it.
   / Steam Boiler or Steam Generator for Weed Control #17
Why don't you go on youtube and check out the natural weed k;illers????
willy
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED FUTURE 24"...
2011 Dodge Ram 3500 Crew Cab Pickup Truck (A59230)
2011 Dodge Ram...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
PALLET OF (3) CABINETS (A60432)
PALLET OF (3)...
