Stater fuse
/ Stater fuse #1
Frederick1Y
Yanmar fd 15
Hi I have a Yanmar FD 15 tractor 1984 model. I think the fuse for the stater has blown but can't find where it is located. Need help!
/ Stater fuse #2
I can't say about your tractor for sure, but I posted this a little while ago about a typical starter.
startermarked-jpg.831346
The big wire from the battery to the starter usually doesn't have a fuse. Likewise the big ground (normally negative (-)) wire from the battery to the chassis won't have a fuse.
I like to take a screwdriver and short across the solenoid from the battery wire to the ignition wire. If the starter turns, then your battery and starter is OK, and start looking at either the ignition circuit or the safety switches.
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2016 Ram 5500 Flat Bed (A63689)
2016 Ram 5500 Flat...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2716SFL (A61567)
2716SFL (A61567)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
