Stater fuse
/ Stater fuse #1
Frederick1Y
Yanmar fd 15
Hi I have a Yanmar FD 15 tractor 1984 model. I think the fuse for the stater has blown but can't find where it is located. Need help!
/ Stater fuse #2
I can't say about your tractor for sure, but I posted this a little while ago about a typical starter.
startermarked-jpg.831346
The big wire from the battery to the starter usually doesn't have a fuse. Likewise the big ground (normally negative (-)) wire from the battery to the chassis won't have a fuse.
I like to take a screwdriver and short across the solenoid from the battery wire to the ignition wire. If the starter turns, then your battery and starter is OK, and start looking at either the ignition circuit or the safety switches.
Lot of (3) HD Pipe Gates (A66408)
Lot of (3) HD Pipe...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
213064 (A64276)
213064 (A64276)
New Holland 68 Square Baler (A66408)
New Holland 68...
