Stater fuse
   / Stater fuse #1
Frederick1Y
Yanmar fd 15
Hi I have a Yanmar FD 15 tractor 1984 model. I think the fuse for the stater has blown but can't find where it is located. Need help!
   / Stater fuse #2
I can't say about your tractor for sure, but I posted this a little while ago about a typical starter.
startermarked-jpg.831346
The big wire from the battery to the starter usually doesn't have a fuse. Likewise the big ground (normally negative (-)) wire from the battery to the chassis won't have a fuse.
I like to take a screwdriver and short across the solenoid from the battery wire to the ignition wire. If the starter turns, then your battery and starter is OK, and start looking at either the ignition circuit or the safety switches.
1 Oliver Front Weight (A50515)
1 Oliver Front...
2007 Ford Edge SEL SUV (A50324)
2007 Ford Edge SEL...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52748)
1994 Thomas Built...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
Genie GTH-844 (A50120)
